Objavljeno: Pon Jan 04, 2010 09:06 Naslov sporočila: Najdražje ... ! |
Gramofon:
The Goldmund Reference 2 turntable is with it's 300.000US$ the most expensive turntable. Made in Switzerland, only 5 a year are being created, and the first 5 were already spoken for before it's moment of introduction in 2007. The total production will eventually be a maximum of 25. It is capable for the accommodation of three tonearms at the same time, and has a spine-splitting weight of 250kg (over 500 pounds)!
CDplayer:
The Metronome Technologie Kalista transport/C2a signature tube DAC, is known to be the best and most expensive cd player at this side of the galaxy. It comes as two boxes, picture shows the transport, which makes 35.000 US$ of the price. The total price was around 70.000 US$ when released, but inflation has brought the price even further up.
 _________________ ''You can hear a lot by listening !!'' |
Objavljeno: Čet Feb 11, 2010 01:00 Naslov sporočila: |
Na testu imam WEISS JASON transport. Slike ne bom prilagal, ker izgled ne kaže gromozanske cene tega izdelka (okrog 12.000 evrov za novega) Po enem dnevu in pol se Electrocompaniet še vedno dobro drži  _________________ "There are two kinds of fools. One says-this is old and therefore good. The other says-this is new and therefore better." Bob Katz |
mzi.perx
Pridružen/-a: Čet Jun 2008 0:06 Prispevkov: 167 Kraj: PIRAN
Objavljeno: Čet Feb 11, 2010 01:39 Naslov sporočila: |
| JAZZZ je napisal/a: | Na testu imam WEISS JASON transport. Slike ne bom prilagal, ker izgled ne kaže gromozanske cene tega izdelka (okrog 12.000 evrov za novega) Po enem dnevu in pol se Electrocompaniet še vedno dobro drži  |
Aha!Igor bi se ga rad rešil
Verjetno ponuja ugodno nekaj kar ne igra za ta denar
 _________________ MZI.PERX |
Objavljeno: Čet Feb 11, 2010 01:54 Naslov sporočila: |
| mzi.perx je napisal/a: | | JAZZZ je napisal/a: | Na testu imam WEISS JASON transport. Slike ne bom prilagal, ker izgled ne kaže gromozanske cene tega izdelka (okrog 12.000 evrov za novega) Po enem dnevu in pol se Electrocompaniet še vedno dobro drži  |
Verjetno ponuja ugodno nekaj kar ne igra za ta denar |
Ne ne, ni Igor.
Za kakšen denar ne igra? Sej sploh ne veš, koliko bi jaz dal zanj.
Ravno sem hotel vprašati, če ima kdo kakšne izkušnje z njim, pa si se kar sam javil. kaj je tebe motilo in kaj ti je bilo dobro? _________________ "There are two kinds of fools. One says-this is old and therefore good. The other says-this is new and therefore better." Bob Katz |
mzi.perx
Objavljeno: Čet Feb 11, 2010 01:58 Naslov sporočila: |
Verjetno ponuja ugodno nekaj kar ne igra za ta denar 12.000€
Objavljeno: Čet Feb 11, 2010 10:22 Naslov sporočila: |
mzi.perx. Nisi mi še odgovoril kakšne so tvoje izkušnje z Jasonom? _________________ "There are two kinds of fools. One says-this is old and therefore good. The other says-this is new and therefore better." Bob Katz |
nomad
Objavljeno: Čet Feb 11, 2010 11:02 Naslov sporočila: |
Electrocompanieta bo zelo težko posekat. Meni je bil boljši od Audio Aero in Burmestra. Bil je v najožjem izboru, na koncu se mi je zdel Resolution Audio malce boljši.
Ali imaš samo Jason transport ali tudi konverter ?
Po mojih izkušnjah je v tem razredu zunanji transport vedno malce slabši kot pa vgrajen, ne glede na ceno. Verjetno je transport oz. laser v obeh tako ali tako isti. V Jasonu je kolikor vem Philipsov pogon, kar pomeni, da imaš transport in čipe za 200 EUR in škatlo za 11.800 EUR. |
Objavljeno: Čet Feb 11, 2010 11:07 Naslov sporočila: |
| nomad je napisal/a: | | JAZZZ je napisal/a: | Na testu imam WEISS JASON transport. Slike ne bom prilagal, ker izgled ne kaže gromozanske cene tega izdelka (okrog 12.000 evrov za novega) Po enem dnevu in pol se Electrocompaniet še vedno dobro drži  |
Electrocompaniet mi služi samo kot transport, DAC je Stylos HAD. Trenutno v resoluciji avtoritativno poseka ECMja, nisem pa še prepričan, če mi ne igra pretenko.
Pri ECMju pa te drago pridejo masivne štange vgrajene v ohišje  _________________ "There are two kinds of fools. One says-this is old and therefore good. The other says-this is new and therefore better." Bob Katz |
matejS
Objavljeno: Čet Feb 11, 2010 11:43 Naslov sporočila: |
Predost Weissovih produktov je v dig. filtrih (ravno te dni sem bil v kontaktu z njim) - ti so eni top na svetu. Je tudi bolj znan v studijih kot v high-end. Ali uporabljas upsampled izhod ali 44k1 (to bi bilo res skoda)? Pri upsampled izhodu bi bilo potem se vprasljivo, kaj Stylos naredi s svojim dig. filtrom (v tej konfiguraciji ga sploh ne bi bilo slabo bypassat).
Zanimivo bi bilo slisat Weiss Medeo oz. vsaj DAC2. Ga ima kdo?
Matej |
Objavljeno: Čet Feb 11, 2010 13:55 Naslov sporočila: |
| matejS je napisal/a: | Predost Weissovih produktov je v dig. filtrih (ravno te dni sem bil v kontaktu z njim) - ti so eni top na svetu. Je tudi bolj znan v studijih kot v high-end. Ali uporabljas upsampled izhod ali 44k1 (to bi bilo res skoda)? Pri upsampled izhodu bi bilo potem se vprasljivo, kaj Stylos naredi s svojim dig. filtrom (v tej konfiguraciji ga sploh ne bi bilo slabo bypassat).
Matej |
Ima, ima. In je priklopil Jasona na Medejo in mislim, da mu je najbolje igrala kombinacija z 44.1(coax)
Če imaš coax dig.kabel (pozicija 6), potem ti avtomatsko preklopi na 44.1/16 ! _________________ "There are two kinds of fools. One says-this is old and therefore good. The other says-this is new and therefore better." Bob Katz |
Objavljeno: Pet Mar 19, 2010 00:44 Naslov sporočila: |
"Klasična filozofija" gradnja zvočnih omaric,čvrsto,neresonantno ohišje je pred leti omajala povečini italjanska "filozofija lesenih" omaric,ki pogonskim enotam dodajo še lastni zven lesa ...
Da bi se pa lotili zvočne omarice,ki bi bila res "pravi" instrument pa je ostalo bolj ali manj pri experimentih ...
Nova produkcija KISO ACOUSTIC ,ki" kopira" konstrukcijo "kitare" ...
Ohišje je nastalo v "legendarni" produkciji kitar Takamine,ki izdeljuje kitare od leta
1959 ... Pravi "fen" teh kitar je Ry Cooder ...
KISO AC. HB 1 je majhna zvočna omarica,ki na videz ne kaže tega kar v resnici "je" ... Večina jo bo gladko spregledala v poplavi velikih,prevelikih zv. omaric ...
Zvočne karakteristike so po ocenah "poznavalcev" enkratne ... Konkurenca GAMUT,JMLAB,SF,Raidho zveni v primerjavi z njim majhno,sintetično,posredno,zamegljeno in predvsem nenaravno ...
Žal pa "kvaliteta" stane ... Osnovni model v mahagoniju dobite v EU za 13.800 € ... V lesu "hawaiian koa" pa za 17.940 € vse brez stojal ...
V eni od dalnjovzhodnih revij,kjer je dobil nagrado za zvočnik leta so mu dodali med vrline,da je cena_kvaliteta v odličnem razmerju napram konkurenci ...
Ker so Gamut(15.000€)Vienna(12.000€) in Magico(28.000€) predragi !!!
Kiso HB1 igra vrhunsko tudi na dvakrat cenejšem integrircu Accuphase ...
Verjetno ga boste letos lahko slišali na sejmu v Milanu in še prej v Münchenu,ker že ima zastopnika tako v Italiji in Nemčiji ... _________________ ~ ** ~ |
Objavljeno: Pet Mar 19, 2010 10:54 Naslov sporočila: |
Na kretnici ima "prave stvari".
Malenkost boljši standard za pasivne komponente kretnice uporabljam sam in res doda tisto pravo.
Izjemno navdahnjena konstrukcija, klobuk dol.
Še ena draga firma.
http://www.german-physiks.com/ |
hi_musica
Objavljeno: Pet Mar 19, 2010 11:55 Naslov sporočila: |
Ko ravno omenjamo firmo Tekamine, naj povem, da na zvočno zelo interesantnem live posnetku Keith Don't Go avtor in izvajalec skladbe Nils Lofgren uporablja Tekamine kitaro.
Mimogrede:
Na slovenskem MM sejmu je posnetek stalnica, sploh v sobi VKLOP. Za ljubitelje kitarske akustike priporočam celoten album, Lofgren se poleg virtuoza na kitari izkaže tudi vokalno in nič čudnega, da so si ga na oder "prisvojili" znani glasbeniki med drugim tudi Springsteen in Neil Young ... |
Objavljeno: Pet Mar 19, 2010 12:27 Naslov sporočila: |
Še en tak posnetek je Ry Cooder& Bhatt, Meeting by the river.
V celoti posnet na lampaški opremi ima to nenavadno lastnost, da bo glasneje igral na 2X 20W lampah kot na 1KW tranzistorjih. |
ReturnToForever
Objavljeno: Pet Mar 19, 2010 15:24 Naslov sporočila: |
| mestn pu je napisal/a: | Še en tak posnetek je Ry Cooder& Bhatt, Meeting by the river.
Meni pa na lampah in tranzistorjih igra ravno tolk naglas kot potenciometer obrnem. A je moj CD izgubil nenavadno lastnost?  |
