Objavljeno: Pon Jun 24, 2024 15:44 Naslov sporočila: |
| ambasador je napisal/a: |
Ce MQA lucka sveti redece, kot benma navajas, je ocitno nekaj narobe. Nasel tole
....If you're using Roons built in MQA decoder then it will be sending an MQA decoded signal which the Eversolo will display differently as it's not doing the full decode and render. You likely don't have it configured correctly. If you want the device to perform the full MQA decode and render then you need to configure it in Roons device settings to not use Roons MQA decoder and set MQA abilities to decode and renderer. If you do want to use Roons decoder due to wanting DSP then enable the MQA decoder and set decide to renderer only.
Roona ne uporabljam. Sem ugotovil kako je s tem:
na streamerjevem displayu sveti rdece, ce uporabljam Tidal aplikacijo na iPadu in na streamer posiljam preko Tidal Connect, ce pa uporabljam streamerjevo Tidal aplikacijo (ki je sicer nekoliko slabsa od Tidalove), pa pri MQA komadih lucka sveti modro, oz. zeleno. _________________ "Whenever we find connoisseurship operating within science or technology we may assume it persists only because it has not been possible to replace it by a measurable grading." Michael Polanyi |
anjica
Pridružen/-a: Tor Mar 2024 11:28 Prispevkov: 26 Kraj: Ljubljana
Objavljeno: Ned Jun 15, 2025 19:06 Naslov sporočila: Re: Je MQA prihodnost digitalnih glasbenih formatov? |
| ReturnToForever je napisal/a: | Dajmo, za kontrapunkt vinilmaniji, odpreti še debato o kontroverznem dolpoteg formatu Master Quality Authenticated.
Promocijski vžigalniki
" (MQA) is a revolutionary end-to-end technology that delivers master quality audio in a file that’s small enough to stream or download. What’s more, it’s backwards compatible, so will play on any device. And because it’s fully authenticated, you can be sure you’re hearing exactly what the artist approved in the studio."
Izkušnje, primerjave z obstoječimi tehnologijami, problemi.... |
Izredno zanimiva tema |
