knap
Pridružen/-a: Čet Sep 2008 7:49 Prispevkov: 1264 Kraj: MIKLAVĹ˝
Objavljeno: Čet Jun 23, 2011 10:25 Naslov sporočila: |
Simaudio MOON i-3 SE Stereo Integrated Amplifier
http://www.simaudio.com/mooni3.htm
Citiram: |
One single-ended audio input which bypasses the gain stage to accomodate a component, such as a home-theatre processor, whose own volume control is used instead
knap
knap
knap
knap
Objavljeno: Pet Jun 24, 2011 08:51 Naslov sporočila: |
Shengya A-206MK Integrated Stereo Amplifier
http://www.enjoythemusic.com/magazine/equipment/0511/shengya_a_206mk.htm
Citiram: |
The remote controlled A-206MK is a revision of the A-206 (sans MK) that allows the unit to bypass the preamp section completely and operate as a dual mono power amp simply by connecting a preamplifier's interconnect to the input marked “Main Input”, and choosing that input via the front panel or on its supplied remote.
The A-206MK has five gold-plated unbalanced RCA inputs, one of which is the direct input to the amplifier, bypassing the preamp section.
dual mono, se lahko uvrsti na listo?
LP |
knap
Objavljeno: Pet Jun 24, 2011 09:14 Naslov sporočila: |
norveĹľan..
Hegel Music Systems H200 Integrated Amplifier (TAS 211)
http://www.avguide.com/review/hegel-music-systems-h200-integrated-amplifier-tas-211
Citiram: |
For your hard-earned $4400, you get a clean-sounding, powerful 200-watt (350W into 4 ohms), remote-controlled integrated amplifier with just enough input and output pairs to be useful but not cluttered: one fully balanced XLR input, two single-ended RCA inputs, a power-amp input (or home theater bypass), a tape-loop output, two preamp outputs for external amplifiers, and heavy-duty, gold-plated multiway speaker-cable binding posts.
knap
Objavljeno: Sre Jun 29, 2011 12:11 Naslov sporočila: |
tile denseni tudi lahko imajo line input
http://www.densen.dk/index.php?page=products&page2=integrated
s pomoèjo dodatka....
Citiram: |
Audiophile Surround Sound
The SB boards (Surround Boards) are not a technological breakthrough, but they are a revolution as far as new features go. The SB boards are add-on boards for the B-150. The B-150 is a dedicated 2 channel product initially, but by mounting the SB boards you get analog 5.1/ 7.1 line input and 5.1 / 7.1 line preout. This means you can easily connect a surround processor, DVD-player or SACD-player. With the SB boards implemented, you can connect a B-340 (4 channel amplifier) and then have 6 channels (5+1) of high grade amplification. This is a very easy and sonically superior way to enter the world of home cinema or Super Audio surround.
Pridružen/-a: Tor Apr 2008 8:55 Prispevkov: 1627 Kraj: Laško
Objavljeno: Tor Avg 09, 2011 13:20 Naslov sporočila: |
Nekaj za zbirko doma...
Leben CS-600
mariosala
Pridružen/-a: Čet Jul 2008 17:37 Prispevkov: 75 Kraj: MENGEĹ
Pridružen/-a: Sob Nov 2009 12:34 Prispevkov: 998 Kraj: Izola
Objavljeno: Sob Avg 20, 2011 12:51 Naslov sporočila: |
Mimetism 17.2
Objavljeno: Sre Okt 26, 2011 10:36 Naslov sporočila: |
Nekaj dobrega in zanimivega. Mark Levinson slednje imenuje SSP (Surround Sound Processor mode of operation, stran 31)
Mark Levinson No.383.
Objavljeno: Sre Nov 23, 2011 11:57 Naslov sporočila: |
Spet sem malo brskal in nasel nekaj zveri, ki imajo HT-bypass funkcijo in sicer novi
Accuphase E-460
Objavljeno: Sre Nov 23, 2011 12:12 Naslov sporočila: |
ter vsi integrirci od Burmestra. Pri teh je potrebno opozoriti, da je HT bypass vhod zgolj samo XLR (pri vseh razlicicah).
Burmester vhod imenuje Surround Input. Vec na strani 3 navodil za Burmester 051.
Burmester 051
Burmester 082
Burmester 032
Objavljeno: Sre Nov 23, 2011 12:20 Naslov sporočila: |
Malo se mi zdi hecno, da McIntosh ne implementira slednjega vhoda. MA7000 tega nima. Implementacija slednjega vhoda sploh ni nobena umetnost, pac dopustis vhod, ki preskoci predojacevalno stopnjo in to je to. McIntosh se vedno uporablja fizicni mosticek med pred in koncno stopnjo. Torej naceloma bi slo, ampak bi moral vedno preklapljat kable, ce bi zelel ojacevalec poslusat klasicno kot stereo ojacevalec, spet drugic ta isti ojacevalec uporabiti v sistemu hisnega kina. Ampak to ni to.
Uporabniki, ki imajo McIntoshe konstatno pisejo, naj ze enkrat za bozjo voljo dodajo HT bypass, ampak brez posebnega efekta. McIntosh pac ima drugo (ekonomsko) racunico zakaj ga ne doda.
lp, d. |
Pridružen/-a: Pon Jan 2010 11:49 Prispevkov: 1407 Kraj: maribor
Objavljeno: Sre Nov 23, 2011 13:08 Naslov sporočila: |
Zakaj pa je to sploh problem? Ko se umerja glasnost HT sistema se paè na ojaèevalcu nastavi na eno jakost. Ob poslušanju HT se nato stori enako, saj skupno jakost HT itak uravnavaš na izvoru. _________________ Lp
Live and let live. |
Sejem gramofonskih plošè
Nova igraèa je doma......
Zvoèniki - izkušnje - predlog
