Objavljeno: Ned Sep 03, 2023 17:15 Naslov sporočila: |
dule80 je napisal/a: | Naprava podpira tidal connect(nuprime wr2), raĆØunalnik in streamer sta na istem omrežju. Tidala preko raĆØunalnika Å”e nisem imel povezanega. Sem gledal malo nastavitve compa pa mi je ĆØudno da spotify dela normalno tidal ne |
To, da ti deluje na Spotify, nima nobene zveze z delovanjem Tidala.
Tvojega streamerja ni na Tidalovem seznamu podprtih naprav:
https://tidal.com/supported-devices?filter=tidal-connect _________________ "Whenever we find connoisseurship operating within science or technology we may assume it persists only because it has not been possible to replace it by a measurable grading." Michael Polanyi |
Pridruen/-a: Pet Mar 2011 15:36 Prispevkov: 1007 Kraj: Ljubljana
Objavljeno: Ned Sep 03, 2023 18:47 Naslov sporočila: |
Ni mi pa jasno nekaj... Zakaj želiŔ s kompa predvajat v streamer/dac? Preverjeno je zvok direk s streamerja v dac neprimerno boljŔi kot predvajan s kompa v dac. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
dule80
Pridruen/-a: Pet Jun 2014 14:33 Prispevkov: 209 Kraj: Domžale
Objavljeno: Ned Sep 03, 2023 18:57 Naslov sporočila: |
benma je napisal/a: | dule80 je napisal/a: | Naprava podpira tidal connect(nuprime wr2), raĆØunalnik in streamer sta na istem omrežju. Tidala preko raĆØunalnika Å”e nisem imel povezanega. Sem gledal malo nastavitve compa pa mi je ĆØudno da spotify dela normalno tidal ne |
https://tidal.com/supported-devices?filter=tidal-connect |
Hvala za tole. |
dule80
Objavljeno: Ned Sep 03, 2023 19:05 Naslov sporočila: |
luka79 je napisal/a: | Ni mi pa jasno nekaj... Zakaj želiŔ s kompa predvajat v streamer/dac? Preverjeno je zvok direk s streamerja v dac neprimerno boljŔi kot predvajan s kompa v dac. |
Zakaj? Ker sem si pred ĆØasom nabavu nov raĆØunalnik pa probavam v tej smeri mal. Kot vidim da se bo treba držat mobilnih naprav |
Objavljeno: Ned Sep 03, 2023 20:49 Naslov sporočila: |
To je nekao tako, kot bi recimo basket namesto prek tv vmesnika želel na vsak naĆØin gledat prek streama na raĆØunalniku, ki je povezan s tv-jem. Tako nekako. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
BorG
Pridruen/-a: Tor Avg 2020 14:28 Prispevkov: 11 Kraj: Menges
Objavljeno: Čet Sep 14, 2023 09:41 Naslov sporočila: |
Pozdravljeni.
Samo zanima me ali menite, da je v teh platformah in tem naĆØinu posluÅ”anje res karkoli dobrega za ustvarjalce?
Direct quote from the official page of Mr. Peter Frampton?
" For 55 million streams of 'Baby I love Your Way', I got $1,700 dollars. I went to Washington with ascap last year to talk to lawmakers about this. Their jaws dropped and they asked me to repeat that for them."
Folks, as much as spotify and other help people discover bands and bering them music that they might never have heard, they are also exploiting and ripping off the very same bands. Should you stop using them? Probably not gonna happen. Should you write to them and tell them to cut a fairer deal with the odious record companies that ratted us out in the first place? Yeah, we should. What if millions of people "complained"?
LP |
Objavljeno: Čet Sep 14, 2023 12:30 Naslov sporočila: |
OĆØitno je, ali pa Å”e niso ugotovili da ni. Će ne, ne bi nihĆØe ponujal glasbe na teh storitvah.
To se mi zdi sicer malo, ampak ne vem koliko recimo dobijo od radia. MogoĆØe je drugje samo tako netransparentno da ne vedo koliko so jih ogoljufali.
"55 million streams" bi lahko pomenilo da nekdo kupi CD in ga 55 millionkrat posluŔa. |
Objavljeno: Čet Sep 14, 2023 13:51 Naslov sporočila: |
BorG je napisal/a: | Pozdravljeni.
LP |
natanko to je povedno v intervjuju z Marcom Lincetto-m (Ŕef založbe Velut Luna), ki ga je posredoval Sir Oliver.
Ta založba ima tako LP kot Cd produkcijo in toĆØno ve, koliko se kje zasluži. Ni ĆØudno, da so padle dol ĆØeljusti advokatov Petra Framptona kako malo ima od 55 miljonov ogledov. Će Lincetto kritizira stream iz pozicije glasbenika, potem mu gre verjeti.
Res je streaming kao demokratiĆØen a kaj ko je manipuliran in kot novinec ne prideÅ” v ospredje, najdejo te samo ĆØe vedo kaj iskati.
Nikoli ni bilo lahko - je pa zato danes možno uspeti z idiotskim glasbenimi videi. _________________ Carpe Diem |
dabiblo
Pridruen/-a: Pon Mar 2017 14:27 Prispevkov: 154 Kraj: Zasavje
Objavljeno: Čet Sep 14, 2023 22:32 Naslov sporočila: |
To "izkoriÅ”ĆØanje" glasbenikov ima vedno dve plati zgodbe ampak ja, ubogi glasbeniki Å”e za vodo nimajo baje...
TIDAL gives 10% of your $20 monthly subscription directly to your most-streamed artist of the month.
Će je že ravno o Tidalu govora.
Dober ĆØlanek na to temo plaĆØil, sploh zadnji odstavek
https://faroutmagazine.co.uk/music-streaming-best-alternatives-support-artists/
Zgornji podatek v eni prejÅ”nji objavi glede koliĆØini streamov 55mio/1700$ izplaĆØila nikakor ne more držati po javno dostopnih podatkih. ...pa tisti podatek je iz leta 2018 btw. Kaj se je takrat Å”telo za stream nevem ali je to sekunda predvajanja ali minuta ali celoten komad. Beleži se sigurno podatek ko ga strežnik zgolj zabeleži že prvo sekundo, posluÅ”alec pa že naslednjo sekundo lahko gre naprej.
Glede podpore glasbenikom pa seveda, podpira se jih lahko na mnoge naĆØine, tudi z obiskom koncertov. Ćez mesec in pol bo Diana Krall nastopala v Mehiki, karte so tudi po 2.000ā¬/kos, nihĆØe nikomu ne brani da se je ne gre tja podpirati, da ne životari od streamov. |
Objavljeno: Pet Sep 15, 2023 09:48 Naslov sporočila: |
Hehe,
nisem niti advokat niti borec, samo komentiral vsebino ... _________________ Carpe Diem |
dabiblo
Objavljeno: Pet Sep 15, 2023 13:01 Naslov sporočila: |
hehe, ma daleĆØ od tega da bi se tudi jst za koga boril, sploh pa ne za korporacije. Zgolj me motijo enostranski pogledi ter zgolj en ozek zorni kot na zadeve, ki lahko izkrivi marsikaj pri zgodbah.
https://tidal.com/track/45222067
Audiomarka
Objavljeno: Sob Sep 16, 2023 11:02 Naslov sporočila: |
Pri nasi estradi si baje vsi ne morejo privosciti kokaina. Tko da neki mora bit narobe s tem tidalom
Po moje bodo moral natrimat algoritem...
Bluzite brez veze. Pri nas majo nekateri glasbeniki ugrabljen sazas in si talajo, mladi ne pridejo zraven, tlle pa secirate. Take pizdarije k pr nas ziher ni. _________________ Kokain za vse, ne le za peÅ”ĆØico! |
peterca
Pridruen/-a: Tor Nov 2013 14:20 Prispevkov: 33 Kraj: Žabjek
Objavljeno: Pon Sep 18, 2023 08:20 Naslov sporočila: |
Mi romi dobro živimo od glasbe.
PlaĆØila so redna, solarna - po principu pare na sunce.
Stanovski kolege civili, so vsi zasedeni vsaj leto dni vnaprej.
Će je to kriza, naj potem Å”e traja... |
Audiomarka
Objavljeno: Pon Sep 18, 2023 17:56 Naslov sporočila: |
Pa dobr to je drgaĆØ. Estrada si želi dostop do kokaina. Dnevno. To pa ni poceni
Ni to stotka na ĆØelo pa sviraj
Algoritmi hitro pregorijo.
Pri nas je to bolj že 10 let naredil niĆØ pa Å”e vedno kaplja bogato. Tako bi mogli tut na tidalu naredit. D dobijo eni, tisti ta pravi naÅ”i
Å ele pol bi Å”li mi to posluÅ”at Tidal... prej pa naj Å”e mal poÅ”timajo. _________________ Kokain za vse, ne le za peÅ”ĆØico! |
EMMA SQ Finale - April 2024
HIGH-END AUDIO
Glava gramofona? Kaj kupiti?
