Objavljeno: Ned Dec 13, 2009 12:11 Naslov sporočila: Dušenje notranjih stranic zvočnika(in) ali opornice? |
Panel Bracing Experiments
Most books on loudspeaker construction really emphasize bracing. What I found is that bracing helps only at the lowest frequencies, below 100 Hz. Another result that really surprised me is that when the cabinet vibrates, the whole thing vibrates. I had expected the panels to exhibit modal resonance patterns. Specifically, at the corners I expected the vibration to be quite low. Not so. All of my expectations were true at certain specific frequencies, but sweeping over the full frequency band shows remarkably similar behavior, regardless of where the pickup is located. This is not to say that bracing should not be used. In fact, I liberally used 2"x2" braces. But don't expect braces to eliminate vibration, and be aware that damping is a lot more effective than bracing.
http://www.silcom.com/~aludwig/Loudspea ... ction.html
Fajn bi bilo, če bi kako rekli o tem.
Za moj okus zelo dober članek in presenetljive metode in ugotovitve.
Danes sem šel malo preverit kaj naredi bitumen panel, ker so pri meni pristali ostanki bitumen panelov od GWBjevega projekta.
Samolepilne bitumen damping panele sem stlačil v M1 minimonitorje na stranice in učinek je slišen in presenetljiv.
Na lestvici "bližje naravnemu zvoku kot prej", so se povzpeli za najmanj klin, če ne dva(telesa instrumentov, so bolj "otipljiva", ker je očitno kištica imela resonanc kot berač bolh, čeprav je spredaj 2cm mdf, vse ostalo pa 2cm gostozrnata iverka, torej narejena kot se spodobi), hkrati pa so se mi takoj pokazale namerno povzročene nedoslednosti na kretnici med tweeterjem in supertweeterjem(ta del kretnice se mi do sedaj ni ljubilo dokončat).
Seveda sem cvikal, da bo dampiranje z bitumen paneli bas "abjajcalo", ampak, maykomila, zdaj je bas končno kompakten, skoraj otipljiv, jasen in globok in atak ima odličen.
Potem sem se malo čohal po buči, kje sem že prej slišal podobno razkošje z še občutno dosti manj resonancami kište(pa ne da ne bi bil z doseženim zadovoljen) in končno mi je šinilo.
http://www.mark-daniel.com/Pro_En.asp?ProID=14
Pri Audiofillu.
MDji imajo kišto narejeno iz enega kosa na rezonance zelo neobčutljivega materijala, podobnega Kerrocku.
http://www.kerrock.si/intro |
samob
Pridružen/-a: Čet Jun 2008 18:06 Prispevkov: 148 Kraj: Krško
Objavljeno: Ned Dec 13, 2009 12:51 Naslov sporočila: |
Zanima me, kje pri nas lahko nabaviš samolepilne bitumen plošče. Za odgovor se že vnaprej zahvaljujem.
lp Samo |
Objavljeno: Ned Dec 13, 2009 13:07 Naslov sporočila: |
| samob je napisal/a: | Zanima me, kje pri nas lahko nabaviš samolepilne bitumen plošče. Za odgovor se že vnaprej zahvaljujem.
lp Samo | Pri Audioexu s foruma...
Pred lepljenjem jih je dobro dat na toplo in kakor sem razumel članek, ki sem ga linkal, ni slabo bituminizirat tudi kote, kar pri tovarniški vgradnji bitumen panelov(imam Mission 727 in ti imajo s paneli pokrite stranice samo delno) ni pravilo.
V nekem drugem članku sem zasledil, da naj bi bil tanjši panel primernejši, seveda pa je člankov o panelih ogromno, zato sem se odločil, da bi bilo koristno tule povprašat kakšne so izkušnje forumašev z njimi.. |
mitko
Objavljeno: Ned Dec 13, 2009 13:27 Naslov sporočila: |
| mestn pu je napisal/a: |
Menda je tak dumping najbolj učinkovit, če je stran od kotov in stranic. Jaz sem svojo mešanico lepila za les in lepila za rigips nanesel slab cm na debelo in stran od stranic. Kako bi se obneslo do roba pa ne vem. |
DAVOR
Objavljeno: Ned Dec 13, 2009 16:38 Naslov sporočila: |
Pozdrav.
Samolepilne plošče iz bitumenske smole se da dobit tudi v trgovinah z avtoličarskim materialom.
Proizvajalci..Dinitrol, 3M, Silco. Slednja je mehkeša in mogoče bolj primerna za manjše dampiranja...transporti, clocki, kondenzatorji...
Druga 2 sta trša in jih je treba pred uporabi segreti. Fen recimo bo čist pravšnji. Mogoče še ena stvar za opomnit. Če dampirate elektronske aparate je treba povleči dol prozorni film-folijo s katero so prevlečene vse plošče, ker je zelo statična in neg. vpliva na zvok.
Če boste dampirali velike površine lahko uporabite tudi gradbeni ibitol p, pač nalepit ga je treba.
Obstaja pa tudi ibitol oz. bitumen v pasti (Dinitrol). Gosta masa za zalivanje robov v zvočnikh recimo.
l.p. _________________ KISS- Keep It Simple and Smart
Nazadnje urejal/a DAVOR Ned Dec 13, 2009 18:10; skupaj popravljeno 1 krat |
Objavljeno: Ned Dec 13, 2009 17:52 Naslov sporočila: |
| DAVOR je napisal/a: | Pozdrav.
Proizvajalci..Dinitrol, 3M, Silco. Slednja je mehkeša in mogoče bolj primerna za manjše dampiranja...transporti, clocki, kondenzatoriji...
Če boste tampirali velike površine lahko uporabite tudi gradbene ibitol plošče, pač nalepit jih je treba.
Obstaja pa tudi ibitol oz bitumen v pasti Dinitrol. Gosta masa za zalivanje robov v zvočnikh recimo.
l.p. |
Leta nazaj sem na celotno notranjost wooferskih kišt nanesel s čopičem bitumen za strehe in postopek ponovil kake 4X.
Deluje odlično, problem je samo, da tak premaz potrebuje kako leto, da neha smrdet.
Bituminizirane kište sem kasneje opremil z dosti močnejšim driverjem in z njim tudi peake nad 500W lepo igrajo, s tem, da sem jim krivuljo kretnice prilagodil, da igrajo tisto kar minimonitorji ne igrajo. |
