Priste
Pridružen/-a: Čet Apr 2021 9:15 Prispevkov: 33 Kraj: Kamnik
Objavljeno: Sob Jun 18, 2022 17:26 Naslov sporočila: Marantz 4270 info |
Pozdravljeni..
Rabil bi eno informacijo!!
Imam marantz 4270 in bi priklopil marantz 170dc!
Ali lahko priklopim na moj reciver?
[/b] |
Objavljeno: Sob Jun 18, 2022 20:37 Naslov sporočila: |
Z zadnje strani imaš dva pre outa.
Na front preout povežeš dvojni rca kabel hkrati na main in in na končno stopnjo. Podobno lahko dupliraš tudi front in rear kanale, da imaš po dva ojačevalnika na vsakem front kanalu. |
Priste
Objavljeno: Ned Jun 19, 2022 12:22 Naslov sporočila: |
Tole sm nasel samo se tudi ne sanja kako bito priklopil!!
CONNECTING
AN
FOR REAR CHANNELS
EXTERNAL
AMPLIFIER
To use an external amplifier for the rear chan-
nels,
connect the REAR PRE OUT jacks to
the inputs of the external amplifier.
In turn,
connect the rear speakers to the output terminals
on the external
amplifier.
The 4270 will then
supply the power for the front speakers and the
external amplifier will supply the power for the
rear speakers.
CONNECTING
AN EXTERNAL AMPLIFIER
FOR FRONT CHANNELS
To use an external amplifier for the front chan-
nels, connect the REAR PRE OUT jacks to the
FRONT MAIN IN jacks.
Connect the rear speak-
ers to the FRONT speaker terminals on the 4270.
Then, connect the FRONT PRE OUT jacks to the
inputs of the external amplifier. In turn, connect
the front speakers to the output terminals on the
external amplifier.
The 4270 will then supply
the power for the rear speakers and the external
amplifier will supply the power for the front Speakers |
Objavljeno: Ned Jun 19, 2022 17:50 Naslov sporočila: |
Najprej je potrebno vedeti kaj želiš doseči s priklopom.
Uporabljati pre na receiverju in zunanjo končno?
Ali kako drugo kombinacijo? |
Priste
Objavljeno: Ned Jun 19, 2022 18:22 Naslov sporočila: |
| Dabi uporabljal pre na reciverju plus koncno stopnjo.. |
Pridružen/-a: Pet Nov 2008 15:15 Prispevkov: 612
Objavljeno: Ned Jun 19, 2022 19:54 Naslov sporočila: |
Tvoje vprašanje sem razumel, da želiš priklopiti receiver 4270 na končno DC170, saj drugega smisla nima.
Zelo preprosto je. Na zadnji strani receiverja inaš FRONT PREOUT in REAR PREOUT.
Povezovalne kable priključi na FRONT PREOUT in na DC170 v INPUT.
R na R, L na L. Zvočniške kable od front zvočnikov priklopi na DC170, rear zvočnike pa priklopi na receiver na pozicijo rear.
Sedaj si dobil povezavo med receiverjem in dodatnim ojačevalnikom za sprednje zvočnike, zadnji ostanejo na receiverju.
Ne moreš pa priklopiti in upravljati vseh štirih zvočnikov preko receiverja in dodatnega ojačevalnika (DC170), ker ima DC170 samo izhod za par zvočnikov, ali drugače, lahko priklopiš ali sprednje ali zadnje, ne moreš vseh štirih na 1x. Stikalo POWER MODE na zadnji plošči mora ostati nastavljeno na položaj 70Wx2
Na sliki sta oba primera:
Bo šlo?
Lp |
Priste
Objavljeno: Ned Jun 19, 2022 21:00 Naslov sporočila: |
| Hvala vam za sliko zdaj mi bo veliko lazje.. samo zanima me kaksen rca kabel morem kupiti da bom lahko to povezal.. |
Objavljeno: Pon Jun 20, 2022 06:55 Naslov sporočila: |
Uobičajni konfekcijski RCA kabel, ki ga dobiš ob nakupu audio naprave. Potem, ko boš videl kako naprava deluje, si lahko omisliš povezovalni kabel od 20€, pa do nebeških višin, cenovno. Najdeš na oglasih vse sorte RCA kablov, pazi, da ne kupiš kabla, ki je namenjen izključno digitalnemu povezovanju.
Lp |
Priste
Objavljeno: Pon Jun 20, 2022 09:52 Naslov sporočila: |
Malo me bega ker ima na reciverju 2x 2x izhoda
Na 170dc pa samo levi in desni.. gledal sm y kabel ali bi bil tak ok? |
Objavljeno: Pon Jun 20, 2022 10:08 Naslov sporočila: |
Kaj te bega, narisano in napisano je vse. Slika najbolj enostavnega interkonekta.
Lp |
Priste
Objavljeno: Pon Jun 20, 2022 11:29 Naslov sporočila: |
Bega me tisto ker sta 2x L in 2x R na reciverju..
Na 170dc pa samo L in R
Se opravicujem ker toliko sprasujem.. sm bolj novinec v HI-FI vodah..
In se se ucim.. sm pa obema zelo zelo hvalezen za vso pomoc.. |
Objavljeno: Pon Jun 20, 2022 13:08 Naslov sporočila: |
1x R za sprednji desni kanal, PREOUT za izhod + MAIN IN povezava med notranjim predojačevalnikom in notranjim ojačevalnikoin in za vhod neke zunanje naprave(nikakor ne za CD ali kaj podobnega) isto 1x L.
1x R za zadnji desni kanal, PREOUT za izhod + MAIN IN povezava med notranjim predojačevalnikom in notranjim ojačevalnikom in za vhod neke zunanje naprave(nikakor neza CD ali kaj podobnega) isto 1x za L.
Zunanja naprava je lahko, eqilajzer, tudi kakšen predojačevalnik, lahko je receiver, ki ima manj watov od tvojega itd.
V bistvu je to povezava PREOUT in MAIN IN predojačevalnika in ojačevalnika v receiverju in če odstraniš te jumperje, lahko da receiver ne bo deloval, odvisno od notranje topologije. Torej, deluje na principu odklopa in priklopa. Malo zapleteno.
Je kaj bolj jasno?
Lp |
Objavljeno: Pon Jun 20, 2022 17:48 Naslov sporočila: |
Varianta "spredaj" je za priklop signalnih poti za sprednje zvočnike, varianat "zadaj" pa za priklop za zadnje.
Na DC170 lahko priklopiš samo po eni od obeh variant.
Zvočniške kable priklopi na DC170. _________________ "Whenever we find connoisseurship operating within science or technology we may assume it persists only because it has not been possible to replace it by a measurable grading." Michael Polanyi |
Objavljeno: Pon Jun 20, 2022 19:17 Naslov sporočila: |
Pa šena opcija:
1. Na 4270 naredi povezavo iz Rear PREOUT na MAIN IN Front, R in L. Poveži zadnje zvočnike na FRONT terminale na receiverju 4270.
2. Naredi povezavo iz 4270 FRONT PREOUT na Input DC170, L in R. Poveži prednje zvočnike na terminale DC170.
Ne pozabi, ko to počneš, 4270 in DC170 naj bo ugasnjen.
Tako, sedaj imaš vse opcije za DC170 in 4270.
Lp |
Priste
Objavljeno: Pon Jun 20, 2022 19:53 Naslov sporočila: |
Ce sm prav razumel priklopim L in R na Main Front in L in R na 170 dc?
Sm prav razumel?
Zvocnike imam v stereo tako da rabim samo front.. |
