Aleksander44
Objavljeno: Tor Nov 09, 2021 20:57 Naslov sporočila: Internetni radio v Dolby 5.1 |
Poslušanje internetnega radia v stereo tehniki ali katerem od upmikserjev AVR-ja (straight, 2 ch stereo, 7ch stereo, auto) na AVR-ju je nekako zadušeno. Morda se uho razvadi prostorskega zvoka.
Če internetni radio poslušam preko Shield TV streamerja in le ta izvaja upmix na Dolby 5.1 se zvok odpre, basi pridejo do izraza. Internetni radio se posluša v pravem prostorskem načinu.
Nazadnje urejal/a Aleksander44 Sre Nov 10, 2021 09:42; skupaj popravljeno 1 krat |
Objavljeno: Tor Nov 09, 2021 21:47 Naslov sporočila: |
Vse kar (na AVRju) ni analog bypass, direct analog itd...je procesirano. Torej zvok kot si ga nastavil oz. je prednastavljen. Vključno z LFE. Vključno z delayi surround zvočnikov. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Aleksander44
Objavljeno: Tor Nov 09, 2021 22:21 Naslov sporočila: |
When STRAIGHT is pressed and the straight decode mode is enabled, the unit produces stereo sound from the front speakers for 2-channel sources such as CDs, and produces unprocessed multichannel sounds for multichannel sources.
Ne vem, če se čisto razumeva. Hočem reči, da mi noben način, vključno straight ne zveni tako dobro, kot eksterno procesiran v 5.1. Barvna vs. črno bela TV. |
Objavljeno: Tor Nov 09, 2021 22:47 Naslov sporočila: |
Ja potem ti pa tista mašinca napumpa note. Kater reciever pa imaš da ti tako "tanko" igra? _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Aleksander44
Objavljeno: Sre Nov 10, 2021 07:04 Naslov sporočila: |
| Dva zvočnika ne moreta tako napolniti prostora kot jih osem v 5.1 formatu. Yamaha Aventage. |
sullly
Objavljeno: Sre Nov 10, 2021 09:50 Naslov sporočila: |
| Aleksander44 je napisal/a: | | Dva zvočnika ne moreta tako napolniti prostora kot jih osem v 5.1 formatu. Yamaha Aventage. |
Seveda imaš prav.
To sem imel priliko slišati pri nekaterih frendih z AV risiverji. Preklop na stereo je bil netto netto izpod surrounda.
Drži kot pribito, a zakaj?
Drži tudi, da je tisti stereo zelo slab napram namenskemu stereu - se sliši dosti slabše kot je stereo sposoben. Preklop na stereo ti samo razgali vso bedo sistema.
Tukaj bi lahko končal a ker sem danes dobre volje nadaljujem..
Po vrsti:
Za tisočaka dobiš 7.2 naprimer 5015 od Marantza s 180W po kanalu.
Najcenejši 180W pravi stereo ojačevalci začnejo pri najmanj dvojni ceni.
Pomeni vsaj faktor x5 v ceni na kanal, ker AV risiverji imajo še procesorje notri, pa tuner, pa še sto drugih funkcij vključno z ekvalizacijami itd
Isto zvočniki projektirani za surround ne morejo tekmovati v stereo načinu s stereo šampion zvočniki. Suround potrebuje centralni kanal - stereo dober zvočnik zmore centralno sceno brez težav. Ne samo to, gre scena od izven levega zvočnika čez celo steno preko desnega zvočnika in konča izven - pa v globino gre tako kot suround ne zmore.
Res pa ti stereo ne more odzadaj predvajati glasbe.
Tisti ko pa majo dost denarja, si pa lahko omislijo mono končne stopnje, ločene procesorje in ločene predojačevalnike in kupijo temu primerno zvočnike zvočnike, hebat ga, nismo še tam. Menda se lahko downlowda (od 2L) prave, nativne, petkanalne posnetke orkestrov in znalci prisegajo na to. Nisem še slišal a rad verjamem.
Treba je upoštevati da je scena samo en vidik kakovosti - drugi so zelo zaguljeni kot je mikrodinamika, resolucija, koherentnost in v takem redu naprej - vse stvari ki enega povprečnega uporabnika surounda en klinc brigajo. Zato so lahko suroundi poceni, ma če gremo primerjat s stereo, potem je potrebno biti pošten in ne vleči na plano samo en vidik.
Res je tudi, da vrhunski stereo s pravimi stereo posnetki (tipa Blumlein) zmore tudi holografijo - kar v petkanalni reprodukciji ne obstaja niti kot pravljica.
Je pa prav reči, da smo lahko srečni, da obstaja suround - ene vrste sindikalni hifi - ni potrebno veliko potrošiti za občutek zadovoljstva.
Nazadnje urejal/a sullly Sre Nov 10, 2021 10:53; skupaj popravljeno 1 krat |
sullly
Objavljeno: Sre Nov 10, 2021 10:46 Naslov sporočila: |
Zvočnik=zvočnik, stereo (blumlein)=stereo (fake iz mix pulta),high end (dejanski) = high end (iz reklamnega deplianta), watt=watt (recimo direkt udarec boksarja ki stoji na prstih ene noge in isti udarec ko se opre na obe nogi), kabel=kabel...
Ja, je isto, a samo verbalno.
Obstaja zabaven način informiranja - postaviš trditev za katero bi rad izvedel zakaj ne drži. Ok, če ne gre drugače.. |
Pridružen/-a: Pon Okt 2017 23:11 Prispevkov: 2559 Kraj: Kranj
Objavljeno: Sre Nov 10, 2021 10:55 Naslov sporočila: |
Osnovni problem bo verjetno to da je internetni radio slabe kvalitete. Pač so pogosto AAC z nizkimi bitrate-i.
Shield TV s svojim procesiranjem očitno bolje zamaskira.
Meni upmixan surround na AV zveni kot bi imel prižgani dve televiziji, ki nista usklajeni. Skratka kot koncert v areni Stožice (kar je drek).
Prve digitalne klaviature (recimo Roland D-50) so tudi imele ogromno reverba, da se ni toliko slišalo artefaktov. |
Aleksander44
Objavljeno: Sre Nov 10, 2021 13:01 Naslov sporočila: |
| LightBit je napisal/a: | Shield TV s svojim procesiranjem očitno bolje zamaskira.
Meni upmixan surround na AV zveni kot bi imel prižgani dve televiziji, ki nista usklajeni. Skratka kot koncert v areni Stožice (kar je drek).. |
Ja, opis je mord malo grob, ampak blizu. Iz Nvidie pride drugačen. Večina je 128 kbps. |
Objavljeno: Sre Nov 10, 2021 18:24 Naslov sporočila: |
Zato imam pa HT brez centra, main zvočnika odšpilata center fantastično. Vklop nekega centra v budgetu bi bil popopn nesmisel in sem prperičan da tudi downgrade sistema. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
