Objavljeno: Čet Jan 02, 2014 14:19 Naslov sporočila: Psihoakustika |
Da malo oživimo debato:
..there's a number of factors involved in our perception of sound quality, and a lot of them have nothing to do with the sound itself. So in the research that we do, we've looked at the - and we call these things nuisance variables or biases. So one of the ones that we deal with is psychological nuisance variables, which have to do with your knowledge or expectation of what you're hearing. Thomas Edison knew this a hundred years ago. He said people will hear what you tell them to hear. So if you're aware of that you're listening to a violin, you've been told it sounds great, if it costs more money, all of those factors play into your perception of how it sounds... And often it's a case where the price has very little to do with the sound quality.. _________________ Carpe Diem |
Objavljeno: Čet Jan 02, 2014 16:56 Naslov sporočila: |
Po svoje je to dober znak za ljubitelje glasbe. Taki ne rabijo nobenemu dokazovati kako dober hifi imajo, važno da dobijo tako željeni zvok.
Postavlja pa v ospredje potrebno samozavest in (nevtralno) kritičnost do tistega kar se posluša. Ne glede na ime, ceno, dizajn, imidž, bajke in povesti, predsodke, urbane legende in prisotne osebe. Je kot da ščiješ tudi če te gleda pet od njih, hahaha.
Potrebno se je otresti vsega, osvoboditi 'podstrešje', pustiti ušesom in zdravi pameti da opravijo svoje. Če je cilj visoka vernost, je dobra praksa redno obiskovanje koncertov. _________________ Carpe Diem |
Objavljeno: Ned Apr 27, 2014 10:15 Naslov sporočila: Re: Psihoakustika |
| ambasador je napisal/a: | | Thomas Edison knew this a hundred years ago. He said people will hear what you tell them to hear. So if you're aware of that you're listening to a violin, you've been told it sounds great, if it costs more money, all of those factors play into your perception of how it sounds... And often it's a case where the price has very little to do with the sound quality..[/i] |
Na temo mitov o dragih starih violinah, ki naj bi zvenele lepše od novih, je bil izveden eksperiment in rezultat objavljen na straneh ameriške akademije za znanost, kjer so ovrgli mit o zvočni superiornosti starih stradivark napram novim violinam. Tule:
http://www.pnas.org/content/early/2012/01/02/1114999109.abstract
Vnela se burna razprava v smislu, da preizkus ni bil opravljen kot bi bilo treba in sledil je nov obsežnejši, tokrat v koncertni dvorani. Spodaj zanimiv 28 minutni video z dotičnega večdnevnega dogodka v Parizu:
https://www.youtube.com/watch?v=OHXOPjI9l0I
In končni rezultat:
http://www.pnas.org/content/early/2014/04/03/1323367111.abstract?sid=5a3bf425-8e2c-4e71-874b-37790fb8bfb6
Če že profesionalci na kraju dejanja, ko so jim zaprli oči niso imeli blage veze kaj držijo v rokah, oziroma celo preferirali nove violine, se mi poraja vprašanje kako za hudiča na raznih audio forumih pisarije da se na dobrem hi-end sistemu jasno čuje stradivarka. Zanimiva reč tale psihoakustika.  |
orc.perc
Objavljeno: Ned Apr 27, 2014 11:52 Naslov sporočila: |
Pusti violiniste, da živijo v svojem "svetu".
Nikjer ne piše kaj pravi "strokovna publika"...?? _________________ -1/3oct.REar |
Objavljeno: Ned Apr 27, 2014 12:27 Naslov sporočila: |
| Torej vsi, ki nismo slišali resnice v živo, bomo popolnoma tiho. Imam kolega, ki je snemalec in je delal primerjave med Stradivarko in drugimi, je povedal, da so alikotni toni Stradivark, ki jih ločijo od ostale raje, na cca 64kHz, kar je z bednim posnetkom nemogoče prepoznavati. S snemalno tehniko 64bit/384kHz je zadeva seveda drugačna. Ampak vsi tehnični parametri snemalcem ne morejo dati novih ušes in posluha, džabe se matrat. Nekdo, ki bi bil glasbenik, violinist, elektronik konstruktor, snemalec in audio ljubitelj obenem, bi nam lahko kaj povedal, tehniki, kablaši, muzkontarji, audiozlatarji, pa se moramo iz strokovne ocene vljudno odstraniti. Žal |
Objavljeno: Ned Apr 27, 2014 13:08 Naslov sporočila: |
Sem že slišal Stradivarko, pa bi jo moral še mnogokrat da bi morda zaznal razliko do drugih (dobrih) violin. _________________ LP |
Objavljeno: Ned Apr 27, 2014 14:13 Naslov sporočila: |
Tole mora bit šele "orgazmično ubijalska" kombinacija! Poslušanje Stradivark na ta novih Sonus Faber Ex3ma katerih kište so iz enakega lesa kot les, ki so ga uporabljali za Stradivarke. To je les rdeče jelke iz doline Val di Fiemme.
ro-bi
Objavljeno: Ned Apr 27, 2014 14:41 Naslov sporočila: |
Zvočnik ne sme resonirat oz. stranice se ne smejo trest. Če dodaja zven kište k zvoku driverjev, potem je zvočnik slab. Ne glede na material.
Lahko je tudi iz betona, pa mora odigrat vse instrumente čimbolj tako, kot so bili posneti.
Sem pa že slišal za tako filozofijo, da če je zvočnik iz enakega materiala, kot instrument, da je najbolje, a meni se to zdi največja bedarija, saj potem svoj "karakter" doda celemu zvoku.
Je pa morda psihični vpliv (če se navežem na temo) , ob enakem materialu, dosti večji. |
diyfreak
Objavljeno: Ned Apr 27, 2014 15:43 Naslov sporočila: |
| Da je extrema iz istega materiala kot stradivarka je samo reklama in nić drugega. |
Objavljeno: Ned Apr 27, 2014 17:12 Naslov sporočila: |
| diyfreak je napisal/a: | | Da je extrema iz istega materiala kot stradivarka je samo reklama in nić drugega. |
Itaq, da je za ta denar treba naredit neko famo in zgodbo. _________________ Lep je dan |
Objavljeno: Ned Apr 27, 2014 18:12 Naslov sporočila: |
Kako zvenijo vrhunske nove violine napram Stradivarkam ne vem, so pa hude razlike med Amati, Guararneri in Stradivari violinami. V preteklosti je bilo posneto kar nekaj CDjev na to temo se jasno slišijo razlike celo med posameznimi Stradivarkami.
Dragocena G.Tartini_jeva "Guarnerika" na dosegu roke  _________________ ~ ** ~ |
NLP
Objavljeno: Ned Apr 27, 2014 18:13 Naslov sporočila: |
... na Pokljukine borovce pa so pozabili:) _________________ Nenad P. |
Objavljeno: Ned Apr 27, 2014 18:23 Naslov sporočila: |
| ro-bi je napisal/a: | Zvočnik ne sme resonirat oz. stranice se ne smejo trest. Če dodaja zven kište k zvoku driverjev, potem je zvočnik slab. Ne glede na material.
In ko smo že pri violinah... Violina, ki dolgo ne igra ima slab zven a ni z zvočniki podobno !!??
Če iz zgoraj opisanega material zvočnika ne bi(ne sme) "igral(ti)" se to ne bi dogajalo ali pač !!?? _________________ ~ ** ~ |
ro-bi
Objavljeno: Ned Apr 27, 2014 19:09 Naslov sporočila: |
Ohišje violine je namenjeno, da resonira in ojača zvok strun. Pri zvočniku morajo pa driverji igrati in ne ohišje. Ohišje lahko preveriš tako, da na steno prisloniš uho ali stetoskop. Če se zvok dobro sliši ven, potem je ohišje slabo.
Zakaj pa misliš, da so dobri zvočniki, vsi po vrsti, tako težki?
Zvočniki, ki dolgo stojijo, pa na začetku slabo igrajo, ker jim vpetje otrdi in ga je treba razmigat, da driverji spet dobijo primerne parametre. |
Objavljeno: Ned Apr 27, 2014 19:22 Naslov sporočila: |
"v vednost in ravnanje"
...Stradivarko "imamo" v Ljubljani...bilo ih je več...mislim da je samo še ena...
...na violini je samo pokrov iz smreke (ne jelke)...torej najbolj vidni del na vseh fotkah in filmih...po teži in površini je večinoma javor: kobilica, vrat, obod in spodnja dila...če odštejemo strune in opremo: eben, pušpan, snakewood itn...
...da zvočnik ne sme rezonirat?, ne vem...marsigdo ki je slišal KISO misli da je to najboljši monitirski zvočnik...
..."dragocena" Tartini-jeva violina ni Guarnerka...žal... je Don Nicolo Amati iz Bologne...in nima nobene vezi z Cremonsko familijo Amati...
...na Pokljukine (borovce) smreke kar pozabi...
...in res je, vsak lesen inštrument, če se ne "troši", zaspi...vendar hitro pride v formo...hitreje kot glasbenik ki ne vadi...žal
LP _________________ šoo mazgoon |
-> HI-FI |
Časovni pas GMT + 2 uri, srednjeevropski - poletni čas Pojdi na stran 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Naslednja
| Stran 1 od 10 |
