Akustika sobe - zanimivi linki
PrispevekObjavljeno: Pon Feb 10, 2014 18:03    Naslov sporočila: Akustika sobe - zanimivi linki Odgovori s citatom
v AK prinašam izbor linkov, vezanih na akustiko sobe, iz italijanskega Videohifi.com.
Bi bilo lepo, če bi v temi obdržali samo linke in dodajali nove, diskusije pa odpirali v niovih temah, tako, brez smetenja.
Za začetek:
Merilne naprave:
http://www.cross-spectrum.com/measurement/calibrated_dayton.html
http://cross-spectrum.com/measurement/calibrated_umik.html
http://www.cross-spectrum.com/measurement/calibrated_cm140.html
http://cross-spectrum.com/measurement/calibrated_umm6.html
http://www.content.ibf-acoustic.com/catalog/index.php
Software
http://www.hometheatershack.com/roomeq (Multipiattaforma: gratuito)
http://www.artalabs.hr
http://www.holmacoustics.com/holmimpulse.php
http://www.sillanumsoft.org/Italiano/prod01.htm
http://supermegaultragroovy.com/products/FuzzMeasure (Mac OS: a pagamento)
http://www.faberacoustical.com (Mac OS: a pagamento, differenti livelli ed applicazioni)
http://www.kvraudio.com (Database di plug-in: VST, Audio Unit, RTAS)
Vodiči za uporabo software-ja:
http://forum.videohifi.com/discussion/88/rew-room-eq-wizard-guida-for-beginners
Produkti za akusticni tretman sobe
http://www.rpginc.com
http://www.rpgeurope.com
http://www.acusticaapplicata.com/home.php?lang=ita
http://www.auralex.com/products.asp
http://www.vicoustic.com/hifi-home-cinema
http://www.masacoustics.it
http://www.astriaudio.com/qt_line.html
http://www.gikacoustics.com
http://realtraps.com/
Gradbeni materijali
http://www.knauf.it/knaufAcustika.aspx
http://www.isolgomma.com/ita
http://www.polymaxitalia.it
DIY
http://arqen.com (Progetti open source per il DIY di diffusori acustici)
http://www.audiocheck.net
Didaktika
http://www.audiosonica.com/it/corso/post/2/Indice
http://www.studiosoundservice.com/didattica/materiale-didattico
http://www.acoustics.salford.ac.uk/feschools
http://fisicaondemusica.unimore.it/index.html
http://www.hunecke.de/en/knowledge/index.html (Acustica, assorbitori, diffusori, bibliografia)
On-line software
http://www.hunecke.de/en/calculators/room-acoustics.html
http://www.hunecke.de/en/calculators/room-eigenmodes.html
http://www.hunecke.de/en/calculators/loudspeakers.htm
http://www.rivesaudio.com/software/CARA.html
http://www.rivesaudio.com/resources/links/frame.html
http://www.cara.de/ENU/index.php?load=start.html
Zaenkrat toliko. Če imate na razpolago druge uporabne linke pa kar na dan z njimi.
Prispevkov: 6276
PrispevekObjavljeno: Čet Maj 18, 2017 08:08    Naslov sporočila: Odgovori s citatom
Aplikacije za pametne telefone android in ios:
italijani so predstavili dve njihovi za merjenje reverba sobe RT60.
Eden je Riverbero, drugi pa APM Tool.
Posebej ta drugi APM Tool se je izkazal. Naredili so več meritev v različnih sobah s profi opremo,
potem isto ponovili s pametnim telefonom.
http://www.suonoevita.it/it/apm_tool_full_android_e_iphone_uno_strumento_utile_tutti_fare_valutazioni_di_qualit_acustica
Rezultati so bili zelo blizu profesionalne opreme - odstopanje manjše od 0,1 sekunde iznad 500Hz
in 0,05 sekunde iznad 2000Hz.
Izpod 500Hz pa ni zanesljiva meritev. Ponovljene meritve so med seboj odstopale tudi za pol sekunde -
čeprav tudi profi oprema ne blesti pri
raztrosu - zgleda je velik problem tudi ambientalni šum.
Bo treba ponoči pokati balončke.
