kalimero
Objavljeno: Pet Maj 13, 2011 07:42 Naslov sporočila: Novi modeli ojačevalcev |
Lampaš MS-20L:
Output Power: 40W + 40W(8Ω)
T.H.D.: ≤0.7%(1KHz)
Frequency Response: 5Hz~75KHz
S/N Ratio: ≥88dB(A)
Input Sensitivity: ≤0.23V(1KHz)
Vacuum Tube: EL34B x 4 , 6J1 x 8
 _________________ www.marsaudio.eu - zastopnik za Jantzen Audio in Fountek |
kalimero
Objavljeno: Pet Maj 13, 2011 07:44 Naslov sporočila: Hibrid VK-2100 |
Hibrid VK-2100:
Output Power: 85W x 2 (8Ω)
Frequency Response: 10Hz-100KHz(-1dB)
T.H.D.: <0.5%(1KHz)
S/N Ratio: >90dB
Input Sensitivity <250mV
Gross Weight: 13.00Kgs
Input tubes 6N1P x 4 (ECC88, 6N23P)
kalimero
Objavljeno: Pet Maj 13, 2011 07:45 Naslov sporočila: HIBRID DC-222T |
HIBRID DC-222T
Use Toshiba transistor as power output, other parts are buildup with vacuum tube
Adopt famous vacuum tube 12AU7 (ECC82)
The amplificatory of vacuum tube use R-transformer and output power part use toroidal transformer
Use Japanese ALPS motor, WIMA and SOLEN to adjust sound
With remote control function and fashionable appearance
Specifications:
Output Power: 95W + 95W( 8Ω)
190W + 190W(4Ω)
Frequency Response: 20Hz-20KHz(±1.5dB)
T.H.D.: <0.5%(1KHz 10W)
S/N Ratio: >85dB
Gross Weight: 15.00Kgs
kalimero
Objavljeno: Pet Maj 13, 2011 07:46 Naslov sporočila: CD PREDVAJALNIK SD-30A |
Specifications:
Audio Output Signal: 2.3V(±0.5dB)
Frequency Response: 10Hz~20kHz(±0.3dB)
S/N Ratio: ≥110dB(A)
T.H.D.: ≤0.05%
Dynamic Range: >100dB
Channel Separation: 96dB
Vacuum Tube: 12AT7 x 2 (ECC81)
