Audio zablode ... ?
gerchy
Prispevkov: 672
Kraj: 01
PrispevekObjavljeno: Pon Jul 22, 2013 08:34    Naslov sporočila: Odgovori s citatom
A med zablode sodijo tudi slepi testi, na primer tisti, omenjen pred nedavnim? Ko je večina prisegala na poceni sistem za par sto evrov, postavljen na stol, povezan z generičnimi rdeče-belimi interkonekti? Laughing
Pipster123
Pridružen/-a: Sre Mar 2012 14:27
Prispevkov: 100
PrispevekObjavljeno: Pon Jul 22, 2013 08:45    Naslov sporočila: Odgovori s citatom
Ne ne, to imajo vsi slab sluh, če zmanjka drugih argumentov Smile
nomad
Prispevkov: 911
PrispevekObjavljeno: Pon Jul 22, 2013 16:12    Naslov sporočila: Odgovori s citatom
Gre za nepazljivostno gluhost (prosti prevod originalnega izraza Inattentional deafness).
While inattentional blindness is a modern classic in attention and perception research, analogous phenomena of inattentional deafness are less well-known. In music, inattentional deafness has never been demonstrated under controlled experimental conditions, despite of indirect evidence for related effects. We tested inattentional deafness with real music in both musicians and non-musicians. Participants listened to the first 1’50” of Richard Strauss’ Thus Spake Zarathustra, with the experimental group having the task of counting the number of tympani beats and the control group just listening. The unexpected event was an e-guitar solo during the last 20s of this sequence. In Study 1, among non-musicians, only a single person in the experimental group noticed the e-guitar, while 52% of the control group did. In amateur musicians, results were less extreme, but structurally equivalent: When engaged in a simple parallel task, only 38% explicitly noticed the strange guitar, with 68% doing so in the control group. In Study 2, findings were extended to an easier stimulus setting. Results demonstrate that inattentional deafness exists in the musical realm, in close correspondence to known blindness effects with dynamic visual stimuli. The striking effects in the musicians’ group shed a new light on the role of attentional processes in music perception and performance.
https://jyx.jyu.fi/dspace/bitstream/handle/123456789/20887/urn_nbn_fi_jyu-2009411269.pdf
https://www.youtube.com/watch?v=zGKADgFCoeU#at=23
Ušes ne moremo zapreti in naša edina obramba pred zvočno kakafonijo okolice je selektivni sluh. Ta nam pomaga, da slišimo samo tisto kar hočemo (to značilnost so poimenovali Coctail Party Effect).
Poslušanje ni neposredna in statična transkripcija zvoka v naše možgane, ampak dinamična interpretacija. Zato se je pravilnega poslušanja treba naučiti. Še posebej, če hočemo ocenjevati kvaliteto reprodukcije glasbe.
Če se koncentriramo na napačne stvari in recimo poslušamo ali violina zveni podobno kot v živo in ali je bolj agresivna itd, potem gredo bistvene stvari mimo naših ušes.
Slepi testi pa so zavajajoči, ker ne upoštevajo gornjih faktorjev (in psihoakustike nasploh). Samo zato ker zapremo oči in nimamo vizualne informacije, še nismo izničili subjektivnosti.
Nekaj branja na to temo:
http://bps-research-digest.blogspot.com/2012/07/introducing-inattentional-deafness.html
http://en.wikipedia.org/wiki/Cocktail_party_effect
http://computingforpsychologists.wordpress.com/2012/06/29/inattentional-deafness-sound-editing-and-auditory-gorillas/
http://xenia.media.mit.edu/~barons/html/cocktail.html
http://www.ucsf.edu/news/2012/04/11868/how-selective-hearing-works-brain
bojc08
Prispevkov: 643
PrispevekObjavljeno: Pon Jul 22, 2013 16:30    Naslov sporočila: Odgovori s citatom
Vse kar človek zaznava in psihično rekonstruira je naučeno in okolice, ki nas obdaja. Ne razumem najbolje novejših pojmov psihoakustike, ki so povezani z visokimi frekvencami nad 20KHz, ki jih ne slišimo in na bilo kakšen način zaznamo. Mogoče je to marketing???
Vsemu kar prebereš ni za verjet, še sploh z neta. Tam lahko vsak zapiše kar hoče!
Danes se v hi-fi vodah uporablja takšno izrazislovje, da bi lahko napisali kakšen leksikon za laike.
Bojc
sg
Pridružen/-a: Pon Maj 2013 10:39
Prispevkov: 73
Kraj: Lj
PrispevekObjavljeno: Pon Jul 22, 2013 23:34    Naslov sporočila: Odgovori s citatom
Danes sem na hitro preračunal vpliv standardnega RG58A/U kabla dolžine 1m uporabljenega kot interkonekt in 3 m dolžine uporabljenega kot zvočniški kabel za območje od 20hz do 20 khz.
Tudi če zvočniku niha impedanca od samo 2,2 ohm proti neskončno je razlika v slabljenju v celem frekvenčnem spektru pod 1 dB. In to za najneugodnejši primer, ko bi bila najnižja impedanca zvočnika pri najvišji frekvenci, kar pa ni realno.
Kot interkonekt pa, če je izhodna upornost vira ali predojačevalca 1 kohm vhodna naslednje stopnje pa neskončna le dobra desetinka dB. Ker je vhodna realno nižja je vpliv še manjši.
Sedaj me pa prav zanima koliko forumašev (misli da ?) sliši razliko pod 1 dB. Ali bo pa spet treba priznat Eliotu da ima prav...
PrispevekObjavljeno: Pon Jul 22, 2013 23:45    Naslov sporočila: Odgovori s citatom
Malokdo sliši res kaj nad 15kHz, resnica pa je popolnoma drugje. Te neslišno frekvence interferirajo z osnovnimi toni v slišnem spektru in jih, rekel bi pojasnjujejo. Tako se ojačevalci z omejenim frekvenčnim obsegom sonično dosti slabše slišijo kot kakšen monstrum, ki gre do ene 3mHz linearno. Seveda pa je tehnika te vrste občutljiva na motnje in ni za vsakega uporabnika. Nekateri le preradi pretikajo kable na živo.
sg
Prispevkov: 73
Kraj: Lj
PrispevekObjavljeno: Pon Jul 22, 2013 23:56    Naslov sporočila: Odgovori s citatom
Zelo zanimiv je tudi račun, kaj pomenijo tolerance elementov (kondenzatorjev in tuljav pa ponekod tudi upornikov) v zvočniških kretnicah.
Če je toleranca le 1 %, pomeni to pri 5 mikroF kondenzatorju 50 nanoF, pri 5 miliH tuljavi pa 50 mikroH. In pogosto sta taka ali podobna elementa priključena ravno na priključne sponke zvočnikov na katerih drugo stran pride zvočniški kabel...
Zgoraj omenjeni kabel ima pa 0,3 mikroH in 0,1 nanoF na meter !
Predpone sem pisal s celo besedo le zato, da stvar bolj bode v oči Smile
sg
Prispevkov: 73
Kraj: Lj
PrispevekObjavljeno: Tor Jul 23, 2013 00:09    Naslov sporočila: Odgovori s citatom
Pri ojačevalcih višji frekvenčni doseg itak direktno pomeni višjo hitrost, ta pa zvoku nikoli ne škodi.
V kablih s hitrostjo signala težav ni, okrog 2/3 svetlobne dosega. Za zgoraj omenjeni kabel je podatek o kasnitvi 5 nS na meter.
Me prav zanima če se bo oglasil kdo, ki sliši če je kabel hitrejši ali počasnejši. Ker je konec koncev to odvisno od dielektrika Smile Smile Smile
cink
Prispevkov: 164
PrispevekObjavljeno: Tor Jul 23, 2013 10:31    Naslov sporočila: Odgovori s citatom
sg zastonj se trudiš z logiko in izračuni, eni pač 'slišijo' (običajno ti kable tudi prodajajo) Rolling Eyes
sg
Prispevkov: 73
Kraj: Lj
PrispevekObjavljeno: Tor Jul 23, 2013 11:14    Naslov sporočila: Odgovori s citatom
Ja res se zastonj trudim, saj me nič ne stane (za razliko od tistih, ki kupujejo kačje olje).
Zelo enostaven je tudi izračun faznega premika.
Ker je pri 20 Khz in hitrosti signala v kablu 200000 Km/s valovna dolžina ravno 10 Km, pomeni da rabimo več kot 27 m dolg kabel, da pridelamo eno samo stopinjo...
PrispevekObjavljeno: Tor Jul 23, 2013 11:31    Naslov sporočila: Odgovori s citatom
Meni je načeloma všeč tak "znanstveni" pristop, ampak zanimivo bi bilo, če bi lahko kdo na ta način izmeril razliko v zvoku dveh IC kablov...recimo istega proizvajalca, le en kakovostni razred razlike?
Ko bi vsaj bile stvari tako enostavne...
gerchy
Prispevkov: 672
Kraj: 01
PrispevekObjavljeno: Tor Jul 23, 2013 11:37    Naslov sporočila: Odgovori s citatom
... in če predpostavimo, da ljudje pri slepih testih znajo poslušati? Vseeno se zdi smiselno izključiti "vizualni efekt".
Namreč, zanimiva bi bila reakcija ob ugotovitvi, da pravilneje igra poceni sistem. Smile
PrispevekObjavljeno: Tor Jul 23, 2013 12:22    Naslov sporočila: Odgovori s citatom
jacoby je napisal/a:
Nimam pojma zakaj si dal besedo znanstveni v narekovaje?
Ali boš ti iz stališča fizike in elektronike bolje in drugače pojasnil?
Vse kar je napisal SG se mi zdi iz teoretičnega stališča popolnoma korektno.
sg
Prispevkov: 73
Kraj: Lj
PrispevekObjavljeno: Tor Jul 23, 2013 13:22    Naslov sporočila: Odgovori s citatom
Saj se načelno da znanstveno izmerit vpliv vsake komponente na zvok, ampak takega pristopa v praksi še nisem srečal:
postavimo sistem in na njem predvajamo glasbo, ki jo pa namesto naših ušes poslušata dva mikrofona. Lahko tudi nameščena v ušesih lutke, ki sedi na mestu poslušanja. Ta dva signala iz mikrofonov čimprej digitaliziramo in datoteki shranimo.
Zamenjamo poljubno komponento (seveda so to lahko tudi kabli) in ponovimo vajo.
Potem samo še primerjamo datoteke in vse mora biti kristalno jasno.
Pa ni...
Še vedno ne bomo vedeli, kdo razliko, ki bo po vsej verjetnosti nastala in če bo majhna res sliši, kdo pa ne.
Tudi, če bi dobili po menjavi ene komponente identični datoteki kot pred menjavo pa bi se verjetno našel kdo, ki bi trdil, da njegova analogna ušesa zaznajo razliko, ker vzorčenje ni neskončno precizno... Pa še prav bi imel glede slednjega.
orc.perc
Prispevkov: 527
Kraj: Posr.Park
PrispevekObjavljeno: Tor Jul 23, 2013 14:05    Naslov sporočila: Odgovori s citatom
Že ob primerjavi s pasjimsluhom vgotovimo, da smo relativno "gluhi". Merilna tehnika je že (davno) prehitela občutljivost ušesa.
-1/3oct.REar
Stran 5 od 6
