CRV
Objavljeno: Sob Mar 11, 2023 22:00 Naslov sporočila: Več kanalni zvok na youtubu |
Večkanalni zvok 5.1 na you tubu mi ne rata. Naj bi bile nastavitve,vendar te možnosti v nastavitvenem menuju ni!
Imam premium verzijo
Mogoče kdo kaj ve o tem? |
Aleksander44
Objavljeno: Ned Mar 12, 2023 16:31 Naslov sporočila: |
Za premium ne vem. Na navadnem YT lahko vsah naloži kar hoče in označi kar hoče. Vse je dvokanalni PCM. 5.1. boš dobil iz tvoje sprejemne naprave, ko bo naredila upmixing. Ene naprave bolje, druge slabše. |
CRV
Objavljeno: Pon Mar 13, 2023 09:38 Naslov sporočila: |
Ja za nalaganje moraš imet napravo.
Zanima me za predvajanje,ker se najde v navodilih na nastavitvah v menuju.Ampak tako obširnega menuje na mojem premium yt nimam  |
errhec
Pridružen/-a: Sre Avg 2013 7:41 Prispevkov: 21 Kraj: Postojna
Objavljeno: Pon Mar 20, 2023 11:05 Naslov sporočila: |
Note: The setting will only appear for videos and devices that support 5.1 surround sound. 5.1 in YouTube is supported on all 2021 and later TVs, Chromecast, Apple TV, Roku and most Fire TV devices. In addition, many 2020 and earlier TVs may also support surround sound - check your device manufacturer to see if your device supports 5.1 for YouTube.
Predvaljalnik mora to omogočati. |
CRV
Objavljeno: Pon Mar 20, 2023 17:37 Naslov sporočila: |
Tudi na compu novejša verzija nima možnosti vklopa.
Sony tv 75" kd-x8J letnik 2022!
Medtem ko Netflix iz tv dela 5.1
Čudno to  |
errhec
Objavljeno: Sre Mar 22, 2023 06:20 Naslov sporočila: |
The good news is that you don't need to do anything to use surround sound on YouTube TV, but you do need the right equipment for the job. According to Google's support page, as long as you have the YouTube TV app, your device runs on Cobalt 20 or above, and your device and speaker set-up are compatible, you'll automatically get 5.1 surround sound.
Some compatible devices include:
Samsung, LG, and Vizio devices with Cobalt 20 or above.
Traditional Chromecasts.
Android TV.
Google TV.
Roku.
Fire TV Stick 4K Max.
Fire TV Stick.
Fire TV Stick Lite
However, this will work as long as the content you are watching supports 5.1 surround sound. If you need to check whether your device or the channel you are watching are compatible with 5.1 surround, here's what you need to do:
How to Check if Your Device Supports 5.1 Audio
1. Open the YouTube TV app.
2. Go to your profile photo.
3. Select About.
4. Choose App Version.
3. Check the version number in parentheses after the word "Cobalt" (it should be 20 and above).
VIR:
https://www.makeuseof.com/enable-51-surround-sound-youtube-tv/ |
CRV
Objavljeno: Sre Mar 22, 2023 22:08 Naslov sporočila: |
hValazatole,samo ne najdem nikjer verzije!
Ali komu drugemu to rata? |
mcnaget
Pridružen/-a: Čet Nov 2012 12:28 Prispevkov: 143 Kraj: Gorenjska
Objavljeno: Sre Mar 22, 2023 22:31 Naslov sporočila: |
CRV je napisal/a: | hValazatole,samo ne najdem nikjer verzije!
Greš na YT aplikacijo na televiziji na levi strani imaš uporabniški račun na vrhu imaš avatar ali profilno sliko in pod to imaš kar nekaj stvari za nastavljati ali preveriti , proti koncu menija spodaj je zavihek različica aplikacije tam so podatki o verziji. Jaz imam cobalt 23 verzijo.
lpz |
CRV
Objavljeno: Čet Mar 23, 2023 18:46 Naslov sporočila: |
Ok sem našel cobalt 23 verzija.
Samo na nastavitvah med videom pa ni funkcije !
Ali nas tole slovence malo vlečejo z enim forami?
https://www.youtube.com/watch?v=h8DlxWCURNI |
Objavljeno: Sob Apr 08, 2023 19:35 Naslov sporočila: |
Za hec sem sedaj probal in meni dela normano v formatu dolby digital +. Ne vem pa koliko je teh vsebin, jaz sem našel kanal 5.1 Test Clipss and Trials in tam je nekaj te vsebine.
Nisem pa nikjer videl, da bi med samim videom lahko izbiral zvočni format, pač če je v surround tehniki je, če ni pa ni. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
CRV
Objavljeno: Tor Apr 11, 2023 10:59 Naslov sporočila: |
luka79 je napisal/a: | Za hec sem sedaj probal in meni dela normano v formatu dolby digital +. Ne vem pa koliko je teh vsebin, jaz sem našel kanal 5.1 Test Clipss and Trials in tam je nekaj te vsebine.
Nisem pa nikjer videl, da bi med samim videom lahko izbiral zvočni format, pač če je v surround tehniki je, če ni pa ni. |
Ja moram povedati,da sem ugotovil,da mi dela na siol neotu!
Na na lanskem modelu Sony tv pa ne dela nobena vsebina! |
Objavljeno: Sob Apr 15, 2023 20:29 Naslov sporočila: |
Najbrž tv nima dekoderja za dolby/atmos. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Aleksander44
Objavljeno: Sob Apr 15, 2023 21:45 Naslov sporočila: |
luka79 je napisal/a: | Najbrž tv nima dekoderja za dolby/atmos. |
Ima. Morda nima upmixerja. Z njim vsak 2-kanalni vir spremeniš v 5.1 ali Atmos. |
CRV
Objavljeno: Ned Apr 16, 2023 09:57 Naslov sporočila: |
Zanimivo,da je ob tipki na daljincu za you tube še tipka Netflix
In tam so vsi filmi v večkanalnem zvoku  |
Aleksander44
Objavljeno: Ned Apr 16, 2023 17:54 Naslov sporočila: |
Netflix oddaja prostorski zvok, youtube ne.
V TV-ju ni menija, kjer določiš, da se vsi zvoki predvajajo v 5.1 formatu? |
