Meritve v HiFi
PrispevekObjavljeno: Sob Feb 25, 2023 08:42    Naslov sporočila: Meritve v HiFi Odgovori s citatom
Zanimivo je mnenje Nelsona Passa o meritvah v HiFi. On sicer v glavnem omenja ojačevalnike, vendar lahko vsebino apliciramo tudi na meritve ostalih komponent HiFi sistema:
"…There has been a failure in the attempt to use specifications to characterize the subtleties of sonic performance. Amplifiers with similar measurements are not equal, and products with higher power, wider bandwidth, and lower distortion do not necessarily sound better. Historically, that amplifier offering the most power, or the lowest IM distortion, or the lowest THD, or the highest slew rate, or the lowest noise, has not become a classic or even been more than a modest success.
For a long time there has been faith in the technical community that eventually some objective analysis would reconcile critical listener’s subjective experience with laboratory measurement. Perhaps this will occur, but in the meantime, audiophiles largely reject bench specifications as an indicator of audio quality. This is appropriate. Appreciation of audio is a completely subjective human experience.
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment.”
Prispevkov: 1977
PrispevekObjavljeno: Sob Feb 25, 2023 10:23    Naslov sporočila: Odgovori s citatom
Meritve za audio namen so dobra osnova za interpretiranje kvalitete zvoka, ki ga slišimo, niso pa ultimativne. Večina meritev bazira na treh vrstah signalov, ki so osnova za izvajanje. Tako največkrat uporabljani sinus večinoma gledamo, kako je sestavljen pri 0V, ko gre signal preko nule. Trikotni signal nam razen pravilne oblike govori, koliko so vršički vhoda pred vršički izhoda iz ojačevalca (faza). Kvadratni signal nam osvetli karakteristike ojačanja, tako položnost strmine naraščanja izhoda proti vhodu, kot tudi ustavljanje signala na peaku signala. Če je zaobljen, je prepočasen in temen, če ima špičke, je to tako imenovani ringing, ki daje svetel, umetno odprt zvok. V Photoshopu je to komanda sharpen ali na TV ostrina, ko se signal slike da malo iz postaje, centra. Ravnina in nagib kvadrata nam tudi pove ali je ojačevalec dušen ali ojačuje. Iz teh treh meritev se s sweep funkcijo pogleda tudi linearnost v predvidenem frekvenčnem območju. Tukaj se pa neha električni del zvoka, nastopi resnica. V glasbi NI sinusa, le-ta je nosilni del, oplemeniten in predelan z alikoti za barvo glasu, inštrumenta... Tako je signal violine na 1kHz in čela na 1kHz z drugačnimi dodatki, v obliki divertiklov na čevah. Če pa je na 1kHz sinusu na +- strmini 50 teh valovčkov, je to v resnici signal 50kHz, imponiran v 1kHz. Če ojačevalec v slišnem frekvenčnem poteku zaostaja standardnih 20°, alikoti igrajo časovno pozneje. To mi zelo dobro ločimo in slišimo s teoretično sicer frekvenčno ubogimi uhi. To je pojav psihoakustike, ki je evolucijsko razvita za našo obrambo. Vedno želimo dognati smer šumov in kaj za en vrag se nam bliža. Prepoznamo svojega otroka na dvorišču, ko se dere, pa se vsi otroci derejo s cca 500Hz. To nemerljivost pa vzamejo v roke sugestivni guruji in nam razlagajo teorije po svoje, najraje s polaganjem rok in šloganjem. Zelo je zanimivo, da se v električni del zelo radi spuščamo in kregamo, širjenje zvoka, pa nam je španska vas. Tako skoraj nobeden ni bral Linkwitza (Linkwitz, Rilley, Pass so bili družba), ki je brezplačno razlagal teorijo zvoka in korelacije med vrstami virov. Bil je namreč šef razvoja pri HP za infra ton, to so sonarji za ribe lovit ali podmornice. Prepiramo se o osnovah, ker smo različno načitani, beremo pa itak samo tisto, kar poznamo in nam je všeč. Še najbolj pa motijo registri cen posameznih izdelkov. Kako je lahko en drat vrednoten kot Chord Hugo TT2, skupaj z Upsamplerjem spodaj, kot ta znameniti zadnji meter drata od Šoštanja do Bežigrada. Priznam resnico, da je to vrednost dveh mojih avtov in HiFi sistema skupaj. K sreči ne dosežem teh investicij, se pa rad seznanim z novostmi.
Nazadnje urejal/a joztom Sob Feb 25, 2023 10:52; skupaj popravljeno 1 krat
Prispevkov: 2560
PrispevekObjavljeno: Sob Feb 25, 2023 10:40    Naslov sporočila: Odgovori s citatom
Meritve so lahko elektronske ali akustične, ko poslušamo pa je v igri psihoakustika. Psihoakustike vsaj zaenkrat še ne znamo izmeriti.
Potem so še vprašanja:
- Ali smo izmerili pravilno?
- Ali smo izmerili vse?
- Ali v praktičnih pogojih deluje enako kot v pogojih v katerih smo merili?
- Kako sploh interpretirati meritve?
- Kakšni rezultati so potrebni?
Prispevkov: 6287
PrispevekObjavljeno: Sob Feb 25, 2023 11:58    Naslov sporočila: Odgovori s citatom
V sosednji temi se kreše okoli Science Audio Review, pa se mi zdi primernejša tale tema.
Njihov pristop bo vedno skregan z avdiofili iz preprostega razloga, ker rinejo v zvočno nevtralno smer, avdiofili pa padajo dol za koloracijami. Tako preprosto.
Ne da se opisati zvoka s številkami, niti dobre številke niso garancija za dober zvok. So pa lahko pokazatelj koloracij in neželjenega obnašanja, kar pa moti velik del avdiofilov, jemlje miren spanec.
Nevtralne naprave so brezbarvne, so zvočni nič. Brez karakterja, jih je nemogoče 'decifrirati'. Imajo pa to prednost, da pustijo posnetku imponirati svoj zvok.
To pa prinaša eno veliko pomanjkljivost - če izvor zvoka zveni revno si bogi, vse bo ena revščina. In izvori zvoka imajo to grdo lastnost, da če nimajo pedigreja (taki pač stanejo) ne igrajo dobro na nevtralnih napravah. Slednje samo spustijo skozi kar dobijo.
Ok, kaj zdaj - imaš izvor ki je mižerija - pač dodaš kolorirane naprave, ki na svoj način (a vedno z istim štempljem) naredijo vse skupaj prebavljivo. Kabli sodelujejo, ko se naveličaš, najdeš druge, ki ti na drugi način obnovijo strast. (še kako vplivajo na zvok, še posebej v groundloop pogojih) Ko niti to ne pomaga, je čas za menjavo katere od naprav. Tako preprosto.
Če pogledate slušne teste relativno nevtralnih naprav (naprimer Benchmark LA4, Topping Pre90) se večkrat vprašajo v primerjavi naprimer tudi z mnogokratnik dražjim Nelson Pass pre-jem - ki je seveda zvočno boljši - da ni ta boljšost umetno narejena? Prišla prilika in za hec sem nabavil Topping Pre90, da se prepričam... meril ga je Amir, meril ga je Atkinson ..
Right-Fi
Prispevkov: 188
PrispevekObjavljeno: Sob Feb 25, 2023 16:34    Naslov sporočila: Odgovori s citatom
Dobro da se je odprla ta tema. Za (moj) začetek bom skušal najprej razjasniti pojem avdio stroke, kot ga razumem sam. Zame avdio stroka zajema dejavnost, s katero se raziskuje in pojasnjuje pojave z audio področja, v nadaljevanju pa se pravilnost rezultatov teh raziskav znova in znova preverja, hkrati pa se na osnovi rezultatov razvijajo nove rešitve (metode, koncepti, posamezne naprave, sistemi, …). Stroka pomeni to, da za osnovo vzamemo rezultate raziskav, ki so jih opravili drugi pred nami in jih objavili v publikacijah strokovnih združenj v obliki recenziranih člankov. Poudarjam pomen recenziranih, ker se na ta način izognejo, da bi se v publikacijo prikradle napake, slabo preverjena dejstva, subjektivna mnenja interpretirana kot dejstva itd. To so strokovni in znanstveni članki.
Na drugi strani imamo množico zapisov druge vrste – monografije, članke v poljudnih ali specializiranih revijah, poste na forumih in blogih, … To je sicer še vedno lahko strokovno gradivo, vendar ne v strogem pomenu besede, kot recenzirani članki in rezultati raziskav. To pomeni, da nekega besedila avtorja, ki je sicer v določenih interesnih krogih zelo poznan in slaven, objavljenega bodisi v monografiji ali v reviji ali blogu, ne moremo avtomatsko in nekritično šteti za strokovno nespornega. Če se v njem ne sklicuje na verodostojne vire, kot sem jih navajal prej, je treba takšne zapise jemati z nekaj rezerve. Enako velja za vsebino, ki se nahaja v ASR (Audio Science Review). Prednost ASR-ja kot vira informacij osebno vidim v tem, da člani, moderatorji pa še posebej, zelo pazijo na povezljivost izjav z dognanji iz stroke. Sklicev na relevantne raziskave je tam res veliko.
V tej luči in v izogib neskončnim prerekanjem o tem, kdo od naših referenc ima prav, je treba vir preverjati bolj kritično, ne glede na njegovo slavo.
Druga stvar, ki se mi zdi pomembna pri interpretaciji meritev v audiu, so metode preverjanja in dokazovanja slišnih razlik. Pravzaprav je to še bolj pomembna stvar, kot meritve same. Po mojem mnenju morajo meritve služiti kot orodje za razumevanje dokazanih slišnih razlik. Če slišne razlike niso dokazane, nima smisla meriti, ker je itak že dovolj dobro.
Seveda meritve dajejo neke smernice glede končnega rezultata na primer nekega ojačevalca. V končni fazi pa šteje le to, ali so pri dveh napravah slišne razlike ali jih ni. Glede problematike dokazovanja slišnih razlik pa sem že podal nekaj linkov v sosednji temi glede kablov.
Pa še tretja stvar, ki me žuli. Veliko se piše o tem, da je neka naprava zvokovno boljša od druge. To je sicer povsem legitimno mnenje posameznika, vendar je to mnenje pomembno in relevantno le za tega posameznika, za večino ostalih pa zelo malo. HiFi pomeni verno reprodukcijo in najboljše naprave so tiste, ki so zvokovno transparentne. To pa ne pomeni, da so za vsakogar tudi zvokovno najboljše, ker je vmes njegov okus, percepcija naravnega zvoka, pristranskost, skratka subjektivnost. Se strinjam, da so triode lahko zvokovno nekomu boljše, tudi meni so všeč in jih v kakšnem primeru tudi uporabljam. Ni pa to HiFi v absolutnem pomenu besede. HiFi pomeni veren prenos glasbene vsebine z nosilca do površine membran zvočniških enot. Pustimo sedaj še prostor, ki prinese dodatno vsaj 30% (ali še bistveno več) tistega, kar pride do ušes. Če glasba iz hipotetično 100% transparentnega sistema zveni zvokovno revno, je problem v posnetku. Velika večina je takšnih. To lahko seveda rešujemo z napravami, ki obarvajo zvok na način, da so določeni osebi zvokovno boljše, ne pa v absolutnem pomenu besede.
Right-Fi
Prispevkov: 188
PrispevekObjavljeno: Sob Feb 25, 2023 17:34    Naslov sporočila: Odgovori s citatom
Meritve ne povedo vsega o zvoku, ali celo nič? Na osnovi do sedaj izvedenih poskusih se je pokazalo, da dve napravi, ki se na slušnem testu (dvojni slepi test v nadzorovanih pogojih) izkažeta za zvokovno različni, vedno izkazujeta tudi razlike v meritvah. Ali drugače povedano, do sedaj se še ni pokazalo, da bi dve napravi imeli enake meritve, pa bi bili zvokovno različni. To velja tako za elektroniko kot za zvočnike.
In po drugi strani: dve napravi, ki imata meritve podobne, vendar se razlikujejo v vrednostih daleč pod slišnim pragom, na slušnem testu zelo verjetno ne bo mogoče zaznati razlik. Če pa see slišna razlika pokaže, bo to praznik tehnike za inženirje, napeli bodo vse sile, da pridejo zadevi do dna. In prej ne bodo odnehali, dokler se ne razjasni. Menda je bilo vedno do sedaj tako.
PrispevekObjavljeno: Ned Feb 26, 2023 00:38    Naslov sporočila: Odgovori s citatom
@Right-fi:
Z vsem spoštovanjem do tega, kar si napisal. Poskušal bom biti korekten, vendar odkrit.
Kot prvo, ponovno opažam, da imaš težavo s poznavanjem in priznavanjem avtoritet. Nekdo, ki pove, da Nelson Pass ni relevanten vir, hkrati pa svojih trditev o znanstvenih testih, ki naj bi dokazovali nekaj nasprotnega, ne podpre z niti enim primerljivo relevantnim virom, je, milo rečeno, izrazno nekorekten. Nelson Pass je skonstruiral, izmeril, poslušal (in seveda tudi prodal) več ojačevalnikov, kot jih bo marsikateri audiofil slišal v svojem celotnem življenju. Po njegovih brezplačnih načrtih je nastalo na desetine DIY variant njegovih ojačevalnikov, ki po mnenju mnogih poznavalcev po vsem svetu zvenijo odlično.
Kot drugo, svoje trditve utemeljuješ na predpostavki, da so inženirske metode in meritve zajele že vse mogoče pojave v avdio napravah in da so obstoječe metode/meritve popolne. Pojav, ki ga trenutno ni mogoče znanstveno opisati in izmeriti, po tej logiki sploh ne more obstajati. To je, glede na dejstvo, da znanost nenehno napreduje, dokaj predrzna, hkrati pa tudi nekoliko smešna trditev. Pošteni znanstveniki namreč priznavajo, da še zdaleč ne vedo vsega.
Nelson Pass med vrsticami pove: merilni instrumenti so bili izdelani predvsem zato, da bi konstruktorjem naprav pomagali ugotoviti kaj se dogaja z njihovimi napravami. Instrumenti merijo določene pojave v napravah. Pri tem so sicer zelo natančni, vendar omejeni (točno določen instrument za točno določeno meritev).
Merilni instrumenti avdio naprav ne morejo izmeriti kako človeški možgani dojemajo zvok, ker niti niso bili narejeni za to in ker je nabor pojavov, ki jih lahko izmerijo današnji merilni instrumenti, očitno mnogo manjši od nabora informacij, ki jih zaznajo, obdelajo in upoštevajo človeški možgani (njihovega celotnega nabora in kompleksnosti sploh ne poznamo). Zadnjič smo že omenili nekaj kompleksnejših fenomenov, ki jih slišimo ob poslušanju glasbe, ki jih ne moremo neposredno povezati z nobeno od trenutno znanih znanstvenih meritev avdio naprav. Ne izključujem možnosti, da bo znanost v prihodnosti odkrila nove pojave in meritve, ki bodo to omogočili. Baje so nekateri proizvajalci opreme že razvili nove metode/instrumente, ki pa jih varujejo kot svojo skrivnost, oz. konkurenčno prednost, zato še niso splošno dostopni. Že to dejstvo pove, da so te metode/instrumenti prvenstveno namenjeni proizvajalcem opreme in ne poslušalcem.
Zelo mi je všeč misel, ki jo imam zapisano v footerju svojih sporočil. Zapisal jo je zelo tehničen človek. "Connisseurship" (poznavalstvo, nemško: Kennerschaft) se lahko pojavi v znanosti oz. tehnologiji, in sicer takrat, kadar ga ni bilo mogoče nadomestiti z merljivim ocenjevanjem (merjenjem).
Ne glede na to, ali nam je to všeč ali ne, "poznavalstvo" je torej lahko del znanosti, kadar/dokler ga znanost ne more nadomestiti/ovreči z merljivim ocenjevanjem. Poznavalstvo je zato ustrezna beseda za opis celovite evaluacije avdio naprav in za naše doživljanje zvoka, ker poznavalstva ne morejo v celoti nadomestiti merljive ocene (rezultati meritev), saj mnoge trenutno sploh še ne obstajajo, oz. je nabor poznanih/izmerjenih pojavov očitno premajhen, da bi zamenjal poznavalstvo.
Znanost je omejena z omejitvami orodij, ki jih uporablja. Njena orodja so kvantitativna, zato lahko znanost odgovori samo s kvantitativnimi odgovori, predhodno pa mora sploh odkriti/definirati pojav, ki ga bo preučevala/merila. Zaradi obojega znanost trenutno še ne more v celoti znanstveno odgovoriti na vprašanja našega doživljanja zvoka. V to, ali je to prostor za vstop raznih šarlatanov, se ne bom spuščal. Obstoj nekaterih šarlatanov še ne pomeni, da smo vsi, ki mislimo, da znanost ne more dati vseh odgovorov, zavedeni od šarlatanov. Obstoj majhnega števila ponarejenih bankovcev v obtoku še ne pomeni, da je ponarejen ves denar v obtoku. Na teh nemerljivih področjih jaz zaupam kredibilnim "poznavalcem"/avtoritetam z referencami kot sta npr. Nelson Pass in Robert Harley (človeku, ki je v svojem življenju za najuglednejše revije testiral na stotine avdio naprav in je rekel, da je zanj bilo vedno pomembneje kar je slišal v poslušalnici in ne to, kar je izmeril v laboratoriju) ter svojim ušesom. Smo dokaj usklajeni.
Kot Štajerc se povsem pridružujem Passovemu mnenju o vinu: Kemična analiza vina ne pove vsega o tem, kako bo pivec vino doživel v svojem grlu, ko bo naredil požirek ali dva. Zato so tudi tukaj potrebni poznavalci.
sg
Pridružen/-a: Pon Maj 2013 10:39
Prispevkov: 73
Kraj: Lj
PrispevekObjavljeno: Ned Feb 26, 2023 11:58    Naslov sporočila: Odgovori s citatom
benma je napisal/a:
@Right-fi:
Kemična analiza vina definitivno lahko pove, ali je v dveh kozarcih isto vino. Marsikateri pivec pa o tem pri slepem testu ne bo prepričan.
Vsaka podobnost z dojemanjem zvoka pri slepih testih je zgolj naključna Very Happy
Right-Fi
Prispevkov: 188
PrispevekObjavljeno: Ned Feb 26, 2023 16:33    Naslov sporočila: Odgovori s citatom
@benma, spoštujem tvojo odločitev za umiritev žoge, tako je dialog precej lažji. Odprl si kar nekaj dilem in tem, ki so že ves čas prisotne v naših krogih in v katerih ni doseženega konsenza med zagovorniki, v grobem, dveh različnih pristopov. Ta dva pristopa je na najkrajši možni način opisal @ambasador:
Seveda je to precej poenostavljeno in brutalno direktno napisano, vendar se v osnovi lahko le strinjam.
Nelson Passpo mojem mnenju izrazito spada v avdiofilski tabor, kjer upravičeno uživa velik ugled. Tudi sam osebno mu lahko glede tega namenim le globok in ponižen poklon za njegovo delo. Kar pa ne pomeni, da se moram v prav vsaki stvari, ki jo izreče ali napiše, strinjati. V znanstvenem in profesionalnem okolju pa po mojem vedenju in nekaj poizvedovanja po netu ne uživa kakšnega posebnega ugleda, nisem našel da se ga kje omenja. Razlog je po mojem v tem, da pač zagovarja drugačno paradigmo od znanstveno utemeljene (audiofilska vs popolna transparentnost). Torej, vsekakor Pass prek svojega dela in objav uživa ugled, vendar ne na način, kot ga pojmujejo v znanstvenih krogih:
https://ieeexplore.ieee.org/document/8791146
https://researchguides.uic.edu/if
in tukaj, kjer pa se ocenjuje tudi kredibilnost online virov¸:
https://www.researchgate.net/publication/339045649_Credibility_evaluation_of_scientific_information_on_websites_Designing_and_evaluating_an_exploratory_model
Hotel sem le pokazati, kakšno pomembnost namenjajo presojanju virov informacij v znanstvenih in tudi strokovnih (profesionalnih) okoljih. V hobiju je to drugače, v avdiofilstvu več ali manj vladajo avtoritete in guruji. Iz praktičnih razlogov to večini zadošča. Če hočeš nekaj več, moraš iz tega nekako izstopiti in pogledati tudi drugam ter tisto razumeti. To je ves point, kot ga sam razumem.
benma je napisal/a:
Sem iskal, kje sem to napisal na tak način, kot ga povzemaš, pa nisem našel. Lažje bi bilo, če bi ti to citiral. Z vsebino odebeljenega teksta se nikakor ne strinjam, moje razmišljanje niti približno ni takšno in me čudi, da bi to na ta način kjerkoli napisal. Morda sem se nejasno izrazil (npr. »vse mogoče meritve«, mislil pa sem mnoge, številne), ne vem. Prosim citiraj, če ti je pomembno. Trdim pa, da na osnovi rezultatov meritev neposredno, ponekod pa le posredno lahko sklepamo na končni zvokovni rezultat v smislu transparence – vernosti prenosa vsebine od izvora do zvočnega nihanja zraka. Seveda ne za vse parametre zvoka, kot ga dojemamo, prav gotovo pa ne na lepoto in všečnost zvoka, ker sta ti kategoriji povsem subjektivni. Lahko sklepamo na primer glede subjektivne lastnosti prezentiranja 2D/3D odra na osnovi meritev zvočnika, ali pa na transparenco ojačevalca na osnovi njegovih električnih meritev.
Glede neobstoja pojava, ki ga naj ne bi bilo mogoče znanstveno opisati in izmeriti pa sledeče: seveda lahko obstajajo takšni pojavi. Ravno z 2D/3D je največ težav in različnih mnenj med raziskovalci. To je pojav, ki v svoji fizičnosti ne obstaja in ga direktno ne moremo meriti. To je psihofizični pojav, ki nastane v naših ušesih in možganih kot iluzija prostora. V objektivističnem taboru velja trditev, da je to v večinski domeni lastnosti zvočnikov in akustike prostora, vendar za sedaj na osnovi akustičnih meritev, ki se izvajajo, še ni možno natančno predvideti tega efekta. Zato ga je tudi potrebno raziskovati izključno statistično na osnovi večjega števila poslušalcev v kontroliranih pogojih. Tu naj bi bilo še veliko prostora za raziskovalno delo.
Najpomembneje pri vprašanju, ali lahko slišano lahko izmerimo pa je, da je slišano najprej treba nesporno dokazati. Dokažeš lahko le tisto, kar obstaja. Če ne obstaja, ne moreš ovrednotiti, izmeriti, … Zato se v audio znanosti priznavajo in raziskujejo le slišni pojavi, ki jih lahko dokažemo z dvojnim slepim testom, izvedenim v kontroliranem okolju in po ustreznem protokolu (glede tega sem že podal en link, kako se to dela).
benma je napisal/a:
Večkrat sem pozorno prebral, kar sem zgoraj citiral, in z vsem se strinjam. (Prosim le, če v zvezi z odebeljenim stavkom navedeš primer fenomena, ki ga ne moremo neposredno ali posredno opisati s poznanimi meritvami. ) Ampak, vedno je en ampak Very Happy. Poglavitna stvar, ki jo razumem kot »kamen spotike« med taboroma (avdifilsko vs. »znanstveno«) je način dokazovanja subjektivnih opažanj. Tega ne morem bolj poudariti. Vsak človek sliši po svoje. Nekateri trdijo, da slišijo več kot drugi in da slišijo pojave, ki jih drugi ne, ali pa jo sliši le določen krog ljudi. Če želimo na osnovi teh trditev in opažanj fenomen raziskovati, moramo najprej te trditve dokazati. V znanosti se priznava le dvojni slepi test (ali morda še kakšna druga metoda, za katero ne vem). Ko je obstoj fenomena na tak način dokazan, se gre v raziskovanje. In do sedaj se je (menda) izkazalo, da so vsi dokazani fenomeni bili dokazani tudi preko meritve ali nabora meritev. Na primer, v Harmanovem laboratoriju (poslušalnica z mašinerijo za menjavo testiranih zvočnikov med seboj) so z dvojnimi slepimi testi v kontroliranem okolju dokazali, da ena skupina zvočnikov bolje prezentira zvočni prostor kot druga (vir informacije lahko na željo poiščem). Merljiva lastnost skupine boljših zvočnikov je, da imajo bolje kontrolirano disperzijo od bolj »flat« zvenečih zvočnikov. Na osnovi te raziskave lahko sklepamo, da nek zvočnik, ki na meritvah izkazuje kontrolirano in enakomerno disperzijo, omogoča boljše zaznavanje zvočnega prostora. Poleg tega je takšen zvočnik prepoznan tudi kot boljši s stališča timbrike.
In če se še obrnem na tematiko kablov. Razlika med dvema kabloma mora biti najprej dokazana na dvojnem slepem testu, nato pa se bo raziskalo in pojasnilo, zakaj je to tako. Nihče iz znanstvenega tabora – ampak res nihče resen - ne trdi, da razlika med kabli ni možna. Med zelo tankim in debelim zvočniškim kablom (mislim na presek vodnika), ki napaja zvočnik z izrazitimi fluktuacijami v njegovem impedančnem poteku menda ni težko dokazati razlike v dvojnem slepem testu (ki pa ga je v praksi precej težko izvesti), ker se spremeni frekvenčna karakteristika. Torej kabel ima vpliv, teoretično in praktično. Na tak način je potrebno raziskovati vse domnevno slišne razlike kablov. Ko bo dokazana slišna razlika dveh električno podobnih kablov (glede vseh relevantnih el. parametrov, ki jih stroka pozna in v smiselnih okvirih*), bo to praznik tehnike, saj se bodo množice raziskovalcev zapodile v to, kaj za tem stoji. Ne verjamem, da bodo odnehali, dokler stvar ne bo pojasnjena. Do takrat pa … nemir med avdiofili in veliki dobički izdelovalcev dragih kablov.
*merilni instrumenti so tako precizni, da v praksi niti dva kabla električno nista identična. Smiselni okviri so razlike električnih lastnostih kabla, kjer je njihov vpliv na delovanje sistema kot celoto tako majhen, da njihove razlike niso slišne. Slišne na osnovi poznavanja mehanizma človeškega sluha. Če na primer na izhod pre-ja z veliko izhodno upornostjo obesimo ekscesno in nenormalno kapacitiven kabel, bo povzročil roll-off na visokih, kar je lahko slišno in sila preprosto izmerljivo, še lažje pa izračunljivo. Very Happy
O vinu pa za sedaj le toliko, da meni vino predstavlja glasbeno vsebino (posnetek), kozarec kot prenosni pripomoček vina v naša usta, pa sistem za reprodukcijo. Menda ne želiš piti vina iz umazanega kozarca? Vino iz lepega kozarca je boljšega okusa? Malo heca, ni čisto tako, vendar kdaj drugič o tem.
PrispevekObjavljeno: Ned Feb 26, 2023 18:39    Naslov sporočila: Odgovori s citatom
@Right-fi:
Mislim, da midva tukaj ne bova razrešila "najine" dileme. Ni mišljeno sarkastično: Iz načina tvojega sicer prijaznega pisanja je razvidno, da si se nekako dvignil nad laičnega ljubitelja dobrega zvoka. Sedaj si v bolj znanstveni sferi, ki ti očitno ustreza. S tem seveda ni nič narobe. Jaz pač bolj zaupam raznim kompetentnim "gurujem" (slabšalno?) in svojim ušesom. Ljudje smo si različni in prav je tako. Poslušanje in doživljanje glasbe pojmujem kot svojevrsten estetski užitek, ki ga ni mogoče povsem izmeriti z nobeno znanstveno metodo. Ko iz kvalitetnega sistema slišim kvaliteten zvok, se mi včasih dvignejo dlake (katera meritev opreme bi lahko napovedala to?).
benma je napisal/a:
"...Historically, that amplifier offering the most power, or the lowest IM distortion, or the lowest THD, or the highest slew rate, or the lowest noise, has not become a classic or even been more than a modest success. ..." (Nelson Pass)
To je dejstvo. Tvoj komentar?
Right-Fi je napisal/a:
Pogrešam kakšen link na znanstvene raziskave, ki so to dokazale.
A sem te prav razumel, da se strinjaš z vsebino tvojega drugega citata mojega besedila? To je bil v bistvu glavni del mojega besedila.
benma je napisal/a:
V bistvu gre za elemente odra, ki nam ga prezentira sistem. To sem omenil:
benma je napisal/a:
Katera meritev bo pokazala, da boš vokal na domačem sistemu slišal peti pred zvočnikoma? Katera meritev bo pokazala, da bo med posameznimi instrumenti slišati več ali manj prostora?
Hec je sicer v redu, vendar ta ponazoritev glede vina zelo dobro izpostavi omejenost znanstvenih avdio meritev. Zakaj imamo sommelierje? Ker so "poznavalci" in ker znanost nima vseh odgovorov na vprašanje katero vino je najboljše. Glede na zamisli, ki jih zagovarjate zagovorniki znanstvenega pristopa, bi bila kemijska analiza vina povsem dovolj. Na vinskih sejmih ne izvajajo dvojnih slepih testov, imajo "poznavalce" (guruje?) sommelierje. Njihova mnenja so odločilna.
Za konec: Večina uglednih avdio revij ob ocenjevanju opreme najprej poda podrobne avtorjeve vtise, ki jih je dobil ob poslušanju naprave. Če dlje časa sledimo neki taki reviji, opazimo, da uporabljajo standardiziran nabor izrazov, s katerimi opisujejo fenomene, ki so jih opazili ob poslušanju. Nekateri imajo standardizirano strukturo besedila (npr. Fairaudio,de). Ko preberemo takšen test, lahko dobimo precej dobro predstavo o napravi. Naprave lahko primerjamo med seboj glede na opisane lastnosti. Na koncu so seveda tudi rezultati in komentar meritev naprave (pri Fairaudio.de recimo meritev sploh ni). Ta del je navadno bistveno manj obsežen od prvega dela. Vedno preberem tudi ta del, vendar mu ne pripisujem večjega pomena.
Vse svoje avdio naprave sem kupil na osnovi takšnega presojanja. Dobil sem to, kar sem prebral/pričakoval in kasneje tudi slišal in sem zelo zadovoljen. Zadnji primer so bili RCA kabli. Če si tudi ti zelo zadovoljen s svojimi napravami, ki si jih izbral na svoj bolj znanstven način, sva oba prišla na isti cilj, pač vsak po svoji poti.
Right-Fi
Prispevkov: 188
PrispevekObjavljeno: Ned Feb 26, 2023 22:02    Naslov sporočila: Odgovori s citatom
benma je napisal/a:
@Right-fi:
Mislim, da midva tukaj ne bova razrešila "najine" dileme. Ni mišljeno sarkastično: Iz načina tvojega sicer prijaznega pisanja je razvidno, da si se nekako dvignil nad laičnega ljubitelja dobrega zvoka. Sedaj si v bolj znanstveni sferi, ki ti očitno ustreza. S tem seveda ni nič narobe. Jaz pač bolj zaupam raznim "gurujem" (slabšalno?) in svojim ušesom. Ljudje smo si različni in prav je tako. Poslušanje in doživljanje glasbe pojmujem kot svojevrsten užitek, ki ga ni mogoče povsem izmeriti z nobeno znanstveno metodo. Ko iz kvalitetnega sistema slišim kvaliteten zvok, se mi včasih dvignejo dlake (katera meritev opreme bi lahko napovedala to?).
@benma, glede na to, da sem se strinjal s kar dobršnim delom tvojega razmišljanja, mislim da nisva tako daleč narazen. Ni pa nobene potrebe, da se v vsem strinjava, ti pojasnjuješ svoja stališča, jaz svoja. In vsak ima svoje argumente, ki se naslanjajo na dve različni paradigmi (glej @ambasadorjevo »definicijo«). Ni bilo mišljeno, da je ena paradigma nad drugo. Eden od trikov tiči v tvoji izjavi, da ti bolj zaupaš svojim ušesom. Predvidevam da predpostavljaš, da zagovorniki z nasprotne strani ne zaupajo svojim ušesom. Resnica je nasprotna. Še kako zaupajo svojim ušesom, vendar s to razliko, da morajo biti v igri zgolj in le ušesa, brez pričakovanj, predvidevanj, pristranskosti itd., kar se zagotovi z dvojnim slepim testom. Glede na tvoje razlage se verjetno dvojnega slepega testa ne poslužuješ. Tebi sicer ta način služi, s čemer ni nič narobe, ni pa prav dosti relevanten za druge, ker ima vsak svoja ušesa, pričakovanja, predvidevanja, okus itd. Pri slepem testu pa smo vsi enako prepuščeni samo svojim ušesom in svojim sposobnostim dejansko nekaj slišati, vse ostalo odpade. Ko v slepem testu zgolj s svojimi ušesi dokažeš kar trdiš da slišiš, pa je to relevantno za vso skupnost, ljubiteljsko in znanstveno, ki mora to tudi upoštevati. »Le« za to gre.
benma je napisal/a:
benma je napisal/a:
Meni pove le to, da ojačevalec, ki je hipotetično gledano žica z gainom v absolutnem smislu, med avdiofili nikoli ni bil legenda, verjetno pa tudi še dolgo ne bo. Razlog za to vidim v tem, da avdiofili kot prevladujoči odjemalci avdio aparatur iščejo pot do zvoka, ki je njihovim ušesom najbolj povšeči – jasno da iščejo zvok čim bližje originalu, kot ga sami pojmujejo. Ker je v celotni verigi ogromno nepopolnosti in kompromisov, se potencialna popolnost ojačevalca izgubi. Lahko je celo moteča, saj ne pripomore k zvoku, ki ga avdiofil išče. Pass razvija rešitve, ki gredo nasproti avdiofilom in je pri tem uspešen.
benma je napisal/a:
Bom poiskal, če dovoliš ti ostajam dolžan tale odgovor.
benma je napisal/a:
Ja, prav razumeš. Zato pa pravim, da nisva tako strašno narazen. Če prav razumem, pišeš o poznavalstvu, ki nadomešča fenomene, ki s sedanjimi meritvami niso zaobjeti. Tudi znanost upošteva to poznavalstvo, uteleša se v obliki treniranih testerjev. To so ljudje, ki so šli skozi proces treninga svojih slišnih sposobnostih po raznih skrbno pripravljenih postopkih (kot sommelierji Very Happy). O tem ima marsikaj za povedati Amir, ki je bil za to usposobljen pri Harmanu:
https://www.audiosciencereview.com/forum/index.php?threads/audio-blind-tests-and-listener-training-video.21026/
Kot sam pravi, poznavalstvo ti mora nekdo priznati, te oznake ne moreš pripeti sam sebi. In v nadaljevanju, da je to tako, kot bi prišel na izpit in profesorju rekel, da znaš vse in sam sebi dal najvišjo oceno. Verjetno ti bo profesor razložil, da to tako ne gre. Tudi poznavalci – testerji, se morajo za dokazovanje slišnih razlik držati protokolov.
Poznavalstvo lahko do neke mere doseže tudi ljubilteljski avdiofil, vendar tudi za njega velja oz. je njemu v korist, če svoje sposobnosti sebi dokazuje s slepimi testi. Izvedba njih je sicer zelo zaguljena. Občutek imam, da smo avdiofili v spološnem pogosto premalo kritični do svojih slušnih sposobnosti.
benma je napisal/a:
benma je napisal/a:
To sem omenil. V bistvu gre za elemente odra, ki nam ga prezentira sistem.
benma je napisal/a:
OK, mislim da sem to pojasnil v nadaljevanju (zvočniki s kontrolirano disperzijo in ustrezna poslušalnica napovedujeta subjektivno dobro prezentacijo odra). Direktno se tega (še?) ne da meriti.
Več prostora med instrumenti: to je zopet izključno subjektivna ocena, ki jo lahko dokazuje poslušalec na slepem testu in v primerjavi z referenco. Absolutne vrednosti ni mogoče podati. Meritve (akustične ali električne), ki bi neposredno določala ta parameter tudi ni. To kvaliteto je moč le predvideti na osnovi, kako dobro so posamezne komponente izdelane, kar se izkazuje z dobrimi rezultati meritev. To bom skušal pojasniti na svojem primeru: vključil sem se v blind test posnetkov, ki so bili narejeni na osnovi reprodukcije štirih različnih izvorov različnega kakovostnega razreda. Link:
https://archimago.blogspot.com/2019/01/internet-blind-test-do-digital-audio.html
Ravno preko prepoznave parametra prostora med instrumenti sem zlahka izločil, kateri vir je »najboljši« in kateri je »najslabši«. Po razkritju rezultatov se je za najboljšega izkazal Oppo UDP-206, ki se tudi po meritvah zelo dobro izkaže. Za najslabšega pa sound blaster v Computer Motherboard - ASRock Z77 Extreme4 (2012). Druga dva vira sta bila iPhone 6 in Sony SCD-CE775, po meritvah vmes med drugima dvema. Poslušal sem s s slušalkami, tako da zvočnega odra nisem ocenjeval. Razlike so bile precejšnje, kot rečeno, razlike v kakovosti posamezne naprave sem najhitreje prepoznal po prostoru med instrumenti.
Menim, da gre ta parameter vštric z množico meritev, ki nakazujejo na majhna popačenja vseh vrst, odsotnost resonanc (pri zvočnikih), delovanje ojačevalca v režimu linearnosti v odvisnosti od kompleksnosti bremena – zvočnikov, ustreznim RT60 poslušalnice, nadzorovanimi zgodnjimi odboji … vse to je merljivo.
Če bi na primer nekdo ugotovil, da ima naprava A več prostora kot naprava B, mora to najprej (sebi) dokazati s slepim testom. Po infomacijah, ki so mi dosegljive, ni podanega in elaboriranega korektno izvedenega primera takšnega poskusa, ki bi pokazal da med napravo A in B ni merljivih razlik s poznanimi metodami merjenja.
benma je napisal/a:
Hec je sicer v redu, vendar ta ponazoritev glede vina zelo dobro izpostavi omejenost znanstvenih avdio meritev. Zakaj imamo sommelierje? Ker so "poznavalci" in ker znanost nima vseh odgovorov na vprašanje katero vino je najboljše. Glede na zamisli, ki jih zagovarjate zagovorniki znanstvenega pristopa, bi bila kemijska analiza vina povsem dovolj. Na vinskih sejmih ne izvajajo dvojnih slepih testov, imajo "poznavalce" (guruje?) sommelierje. Njihova mnenja še kako zelo veljajo.
Za konec: Večina uglednih avdio revij ob ocenjevanju opreme najprej poda podrobne avtorjeve vtise, ki jih je dobil ob poslušanju naprave. Če dlje časa sledimo neki taki reviji, opazimo, da uporabljajo standardiziran nabor izrazov, s katerimi opisujejo fenomene, ki so jih opazili ob poslušanju. Nekateri imajo standardizirano strukturo besedila (npr. Fairaudio,de). Ko preberemo takšen test, lahko dobimo precej dobro predstavo o napravi. Naprave lahko primerjamo med seboj. Na koncu so seveda tudi rezultati in komentar meritev naprave (pri Fairaudio.de recimo meritev sploh ni). Ta del je navadno bistveno manj obsežen od prvega dela. Vedno preberem tudi ta del, vendar mu ne pripisujem večjega pomena.
Vse svoje avdio naprave sem kupil na osnovi takšnega presojanja. Dobil sem to, kar sem prebral/pričakoval in slišal in sem zelo zadovoljen. Zadnji primer so bili RCA kabli. Če si tudi ti zelo zadovoljen s svojimi napravami, ki si jih izbral na svoj bolj znanstven način, sva oba prišla na isti cilj, pač vsak po svoji poti.
Vino se mi itak ne zdi dobra analogija, poleg tega niti približno nisem strokovnjak s tega področja. Sem zgolj ljubitelj zame dobre kapljice. Zdi se mi, da sommelierji niso samooklicani strokovnjaki. Če prav vem, gredo skozi predpisane postopke izobraževanj in na koncu »certificiranj«, dobijo potrditev nekoga da to obvladajo. Enologija ni eksaktna veda, kot je elektrotehnika in akustika, in že iz tega razloga ni primerljiva. Vino je kot glasba, ki ima svoje kakovosti in emocije. Analogno je bolj kot posnetek glasbe, ki se nahaja na nosilcu zvoka. Pa še to ne ravno, saj je posnetek glasbe zgolj kopija - približek žive izvedbe (če ni elektronska glasba), vino pa je v originalu – živi glasbenik pred teboj. Tako to jaz razumem, ne vidim dobre analogije s Hi-Fi.
Pa še tole za konec. Znanost nikakor ni vsevedna, v njenem samem bistvu znanstvenega raziskovanja pa je vgrajen mehanizem stalnega preverjanja pravilnosti dosedanjih dognanj. Naloga tistih, ki trdijo da je znanost v kakšnih segmentih prekratka, pa je ta, da se najprej podučijo, kaj ima znanost s tega področja za povedati. Skratka, da se najprej dobro izobrazijo s področja, za katerega trdijo da ne funkcionira. Znanost ima bistveno več odgovorov na vprašanja, ki si jih laiki znamo zastaviti, tudi v avdio problematiki. Moje mnenje pa ni znanost – da se malo zavarujem…
Prispevkov: 2560
PrispevekObjavljeno: Pon Feb 27, 2023 09:50    Naslov sporočila: Odgovori s citatom
No, ampak si sam že večkrat omenil kako sam interpretiraš meritve. Gledaš kakšno harmonsko strukturo ima popačenje ...
Čeprav bo Amir v zaključku napisal da je zanič, ker ima SINAD 40dB to z lahko ignoriraš.
Ne bi se sicer strinjal da to kar praviš glede nevtralnosti in koloracij univerzalno drži. Ampak če nekdo noče nevtralnosti je vsekakor zgrešil, če je kupil "najboljšega" (najbolj nevtralnega). Če tega ne ve, bo zaključek da so meritve brezveze.
Prispevkov: 1977
PrispevekObjavljeno: Pon Feb 27, 2023 11:51    Naslov sporočila: Odgovori s citatom
Merimo lahko le fizikalne parametre. Glasba ni merljiva in tudi nima oblike. Zato je toliko prostora za šarlatane in k sreči se najde kakšen Amir, v vlogi svetnika, ki se bori proti kačjemu olju. Vse interpretacije meritev so povezane z neko frekvenco, ki je v glasbi ni. Če gledamo orkester na osciloskopu, vidimo travo, slamo ali meglo, nobenih frekvenc in popačenj. Če za predstavo stopimo na dirigentsko mesto v Budimpešti, pred ciganski orkester s 100 violinami, kaj slišimo? Če vse violine cigajo isto frekvenco, so med seboj in še med dirigentom različno oddaljene in zato zvok prihaja v različnem času do nas. V kompleksu je to trava s špičkami nad 100kHz. Kako, da to sploh slišimo, je zaenkrat še uganka. Celo tako zelo dobro slišimo, da ne glede na omejitev sprejemanja mladega ušesa 20Hz-20kHz, stari dirigent loči, kdo in od kje fuša. Torej fizikalne meritve LRC, SPL... stotka, področje psihoakustike, širjenja zvoka ali delovaje možganov ničla. To pa je idealni poligon za naročene sugestivne teste in posledično prodajo audiofilske robe. Slovenija ni tipični porabnik tega, lahko pa si predstavljamo, da na USA trgu s 333mio. personala, rabiš z naročenimi recenzijami nategnit samo 1000 kupcev in z izplenom po 1000$ na enega postaneš milijonar.
Prispevkov: 6287
PrispevekObjavljeno: Pon Feb 27, 2023 12:28    Naslov sporočila: Odgovori s citatom
Točno to - če so meritve odlične, gre za nevtralno napravo in kot taka ne bo deležna pohval avdiofilov. Vsi prisegajo na 'wire with gain' kot ideala, kar tudi je. Toda, priključiš in nič se ne zgodi - ne naredi nič. Vsi pa pričakujejo da ideal naredi magijo. Sam ojačevalec ne svira, je vpet v verigo, kjer vsak člen mora opraviti svojo nalogo. Magijo naredi če pride magičen signal za ga ojačit. Kapito?
Ja, se gleda upad harmonikov - dokler so popačenja v slišnem območju. Ko so popačenja izpod 120dB, je glih vseeno kako se mešajo. Seveda so to dosegali že v preteklosti a z zlorabljenim feedbackom, pa ni sviralo. Prepočasen feedback dela škodo, začne intermodulirati (TIM - tranzient intermodulation).
Nevtralne naprave 'palijo' v studijih. Tam je izvor zvoka master trak in/ali živa glasba preko mikrofona. Pa še za zvočnike ni potrebno skrbeti, ker so v skoraj idealni akustiki na skoraj nevtralni strani. V takem pride posnetek do izraza.
Doma pa 'moraš' (hehe) poskrbeti da se približaš temu, če želiš koristiti beneficije nevtralnih naprav. Čimboljši izvor zvoka torej in pogruntani zvočnik glede na prostor.
Alternativa je kolorirani audio, kar je tudi praksa. Ko se to kapira, zmanjka argumentov za 'dialektično kreganje' Laughing Laughing Razumeš 'koloriste'.
anzec
Prispevkov: 251
PrispevekObjavljeno: Pon Feb 27, 2023 13:11    Naslov sporočila: Odgovori s citatom
Jaz se v tej temi strinjam z benma-jem.
Dodal pa bi to, da je nevtralnost ene same komponente brezvezna, saj se komponenta lahko obnaša drugače na različnih sistemih.
Pa tudi če je sistem nevtralen, je nevtralen po tem kar sedaj merimo, kar je premajhna množica, da bi lahko rekli, da je nevtralen. Enostavno merimo premalo, premalo natančno, morda imamo premalo definirano kaj človeka zmoti in na kaj je toleranten. Lahko človeka zmoti 2db pukel na 1khz, na 200hz pa recimo ne. Lahko človeka zmoti malenkosten časovni zamik 2khz in 200hz, ko se predvajata skupaj. Pogrešam take meritve, res pa je, da bi jih le redki znalo brati, torej bi bila potrebna interpretacija, še pred tem pa gradnja te interpretacije na osnovi katere bi se zgradili neki standardi. to vidim kot nek znanstveni napredek, na katerem smo še precej šibki. Morda pa je ravno to čar hifija.
Stran 1 od 9
