MAYHT
sullly
Prispevkov: 387
Kraj: Globes
PrispevekObjavljeno: Ned Jul 10, 2022 11:10    Naslov sporočila: MAYHT Odgovori s citatom
Nova tehnologija zvočnikov:
https://www.mayht.com/technology
Predvidevajo da bo izpodrinila dosedanjo tehnologijo izdelave wooferjev.
Začelo bo s soundbari, računalniki, tableti, bluetooth zvočniki.
10 cm membrana (v bistvu sta dve) parira 20cm wooferju, s tem da potrebuje bistveno manjšo in lažjo škatlo; wooferja se balansirata (izničita) z vibracijami.
Hod membrane je 50% daljši ker so tuljave zunanje, je bolje vodeno. Spiderja ne potrebuje.
Startup podjetje Mayht je kupljeno za okroglih 100 miljončkov, lastnik je Sonos.
Prispevkov: 2556
PrispevekObjavljeno: Ned Jul 10, 2022 13:08    Naslov sporočila: Re: MAYHT Odgovori s citatom
sullly je napisal/a:
Ne bo, predvsem zaradi patentov.
sullly
Prispevkov: 387
Kraj: Globes
PrispevekObjavljeno: Pon Jul 11, 2022 12:55    Naslov sporočila: Odgovori s citatom
Available to license for any audio-enabled device, across any industry vertical and user application ....
Building out a factory to out-manufacture the existing speaker element manufacturers would be a fools’ errand — one that the company is cleverly side-stepping by taking a licencing approach instead, building a very lean, engineering-focused team, and raising relatively small amounts of money.
There are two people who formerly worked at Philips in the licensing department. One of them actually led the licensing department and made that side of Philips a huge business. He’s really helping us with the licensing structure, but also with how you handle [patent] litigation. He’s also an incredible deal-maker,” explains Scheek.
Noro bi bilo narediti svojo fabriko in vreči iz tira obstoječe proizvajalce, zato raje stopijo na stran in podelijo licence.
Tako bo to šlo.
V taki situaciji menim da noben proizvajalec driverjev ne bo čakal in gledal kaj se bo zgodilo. Vsi bodo poskakali na prvi vlak preden se odpelje konkurenca v prednost. Predvidevam da bo prišlo do prave revolucije, hitrega obrata.
Prispevkov: 2556
PrispevekObjavljeno: Pon Jul 11, 2022 20:15    Naslov sporočila: Odgovori s citatom
Ah, sem videl že več tehnologij "izumreti" zaradi političnih ali licenčnih razlogov. Verjetno zna biti razširjeno med dražjmi malimi igračami. Bomo videli.
Ali so že kje primerjalne meritve popačenja?
Da vidimo koliko drži kar trdijo.
Prispevkov: 928
PrispevekObjavljeno: Tor Jul 12, 2022 08:30    Naslov sporočila: Odgovori s citatom
a za ozvocit koncert bodo pa 16 cm drivercke uporbil Laughing
smo ze videli kup takih in drugacnih tehnologij, ki so umrle se preden so dobro zazivele,...muhe enodnevnice
sullly
Prispevkov: 387
Kraj: Globes
PrispevekObjavljeno: Tor Jul 12, 2022 11:29    Naslov sporočila: Odgovori s citatom
Mislim da je še dosti prezgodaj gledati na to s hifi metrom. Sigurno ima svoje posebnosti, ki bodo morale biti upoštevane in ne bodo take kot dosedaj.
Odziv na višje frekvence, naprimer, posebej od break up-a membrane navzgor. Dokler bo prišlo v hifi uporabo bodo vse to obvladali.
Pomembno za začetek je, da bo prineslo pocenitev na celi črti /cenejši driver, manjša škatla../. Vsekakor ultra manjša škatla pomeni manj problemov, pa še membrane delajo v kontrafazi tako da se sile izničijo/ne trese boxa. Uau faktor (koliko basa iz tako male škatlice) bo naredil svoje.
Odsotnost spiderja (ki centrira tuljavo) pomeni odsotnost sekundarnega vira zvoka. Se je to videlo na zadnji seriji Bowersove Diamond D4 serije, kjer so na srednjetoncu praktično eliminirali standardni spider (to funkcijo sedaj opravlja spider v obliki skeleta, samo nekaj nitk ki drži - so šla popačenja za en red velikosti navzdol. Biomimetic spider:
https://www.bowerswilkins.com/en/product/loudspeakers/801-d4
Kar nekaj specifike nakazuje na preboj v kakovosti.
Prispevkov: 2556
PrispevekObjavljeno: Sre Jul 13, 2022 18:47    Naslov sporočila: Odgovori s citatom
Škoda, meritve imajo pa jih skrivajo. Samo B2B pa NDA moraš podpisat.
Prispevkov: 544
Kraj: Med Koprom in Trstom
PrispevekObjavljeno: Čet Jul 14, 2022 13:23    Naslov sporočila: Odgovori s citatom
Ker me je sprovocirala izjava o "prvih" dvojno balansiranih wooferjih, sem si šel pogledati slike o dejansko enih prvih serijskih izdelkov podobne balansirane tehnologije. Pa se je na nekem forumu oglasil ne človek, ki je to izumil, ampak človek, ki je veliko let preživel z izumiteljem in tudi fizično sestavljal proizvode. Zanimivo je postalo pisanje, kako je vse skupaj propadlo. Zmeraj na enak način - najprej se vrinejo, nato te izrinejo, na koncu te obtožijo. V konkretnem primeru je mimoidoči dobrosrčnež razumel potencial novih idej in sposobnost ekipe in financiral ustanovitev novega podjetja ter jih popeljal v še večjo slavo. D.S.L.
sullly
Prispevkov: 387
Kraj: Globes
PrispevekObjavljeno: Pet Jul 15, 2022 10:35    Naslov sporočila: Odgovori s citatom
'Protinapad' KEF-a:
https://www.hifi-regler.de/testberichte/kef_kc62-kompakter_subwoofer_im_test.php
Gre za dvojni balansirani driver z voice coili različnih premerov (Uni-Core).
Predstavili so tudi LS 60 Wireless zvočnik z dvemi pari takih balansiranih Uni-Core wooferjev. Širina boxa samo 13cm za membrane 13,5 cm premera.
https://www.whathifi.com/reviews/kef-ls60-wireless
Razvoj gre v to smer. Mayht gor ali dol, pri čemer ima veliko prednost, ker je konstrukcija ultra tanjša in s tem veliko primernejša za soundbar, TV, prenosni računalnik, tablet, telefon ... pri tako veliki 'epidemiji' pa hitro pride do preskoka 'okužbe' na hifi.
Prispevkov: 2556
PrispevekObjavljeno: Sob Jul 16, 2022 09:20    Naslov sporočila: Odgovori s citatom
Če bi jaz delal sub z večimi driverji, bi naredil push-pull tako da sta si nasproti.
Zmanjša premikanje škatle in nesimetrije driverjev. Je pa seveda večje in grše.
Pa še ena stvar je za upoštevati. Dodajanje driverjev ne zniža resonance, ki je pri manjših membranah (pri primerljivi učinkovitosti z enako skupno površino) višja.
