Objavljeno: Pet Nov 19, 2021 13:58 Naslov sporočila: |
Itak, ĆØe gledamo na bas kot note glasbila. Å e vedno, ĆØe nekaj ne sliÅ”iÅ”, paĆØ ne vpliva.
Je pa tale netopir vsaj obĆØutno cenejÅ”i, ĆØe bi kdo rad preizkusil. |
Pridruen/-a: Pet Mar 2011 15:36 Prispevkov: 1005 Kraj: Ljubljana
Objavljeno: Pet Nov 19, 2021 14:26 Naslov sporočila: |
Će nekomu ni usojeno, da bi sliÅ”al woofer pod 40Hz, mu je morda poslanstvo, da Å”iri supersoniĆØnost med 50 in 100kHz. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
sullly
Pridruen/-a: Pon Avg 2021 17:26 Prispevkov: 387 Kraj: Globes
Objavljeno: Sob Nov 20, 2021 09:24 Naslov sporočila: |
Kaj ni nobeden Ŕel niti pogledat na spletno stran ali ne razumete ingleŔko? Vas daje kovid?
Pazi - firma ima Å”e druge verzije STW ki so oĆØitno Å”e krepko bolj poceni (Batpure, 45ā¬ par, cena na japonskem):
http://www.taket.jp/batpure/batpure.html
Mini super tweeter celo za dodajanje v sluŔalke!
pa v televizorje - trdijo, da ima smisel tudi tam dodati.
BPP za posluŔanje STW skozi kožo!
http://www.taket.jp/bpp/bpp_e.html |
Objavljeno: Sob Nov 20, 2021 11:23 Naslov sporočila: |
PosluŔanje skozi kožo? V PDF pojasnijo "Vocal of both of the man and woman becomes be sexy."
Francoske zastopnike moraÅ” pa kontaktirati francosko ali "Engulish".
Na vibratorje se pa ĆØisto niĆØ ne spoznam. |
Objavljeno: Sob Nov 20, 2021 13:44 Naslov sporočila: |
LightBit je napisal/a: | PosluŔanje skozi kožo? V PDF pojasnijo "Vocal of both of the man and woman becomes be sexy."
Po mojem, da je to nekaj v vezi z odganjanjem komarjev. Ampak, kakorkoli, meni se za odganjanje komarjev, vse kar je veĆØ od 1,69 ā¬, zdi predrago. _________________ My leader told me to jump in the river. .The river was deep and the weather was winter. .After a sailer very kindly saved me, my leader told me, you'd better take it easy. .I took it so easy my leader called me lazy! |
Objavljeno: Sob Nov 20, 2021 13:50 Naslov sporočila: |
Tole bi bilo zanimivo sliÅ”at na katerih full range in podobnih zvoĆØnikih ki se konĆØajo že krepko pred 20000 Hz.
Ali pa na mojih Bose ^^ _________________ Music was my refuge. I could crawl into the space between the notes and curl my back to loneliness. |
Objavljeno: Sob Nov 20, 2021 14:32 Naslov sporočila: |
luka79 je napisal/a: | LightBit je napisal/a: | PosluŔanje skozi kožo? V PDF pojasnijo "Vocal of both of the man and woman becomes be sexy."
Po mojem, da je to nekaj v vezi z odganjanjem komarjev. Ampak, kakorkoli, meni se za odganjanje komarjev, vse kar je veĆØ od 1,69 ā¬, zdi predrago. |
Za ta namen najbolje delujejo komarniki. So pa lahko malo veĆØ kot 1,69 ā¬. |
Objavljeno: Sob Nov 20, 2021 14:38 Naslov sporočila: |
Pestilence. je napisal/a: | Tole bi bilo zanimivo sliÅ”at na katerih full range in podobnih zvoĆØnikih ki se konĆØajo že krepko pred 20000 Hz. |
V tem primeru bolje kaj takega: https://www.visaton.de/en/products/drivers/horn-tweeters/tl-16-h-8-ohm
Ali že omenjene Fostex visokotonce. Da se stvar lepo prekriva in lahko narediŔ kretnico.
Pri tistih Japoncih Ŕe grafa ni nobenega. |
Objavljeno: Sob Nov 20, 2021 23:15 Naslov sporočila: |
Poglejj si primer suljo. Vse ve, sele letos avgusta se je prikljucil. Sem preprican, da je to avtenticna oseba.
Kako si ti razlagas pojav takilih patronov? Ena varianta je da pozabi vzet tableto zjutraj in pol je suljo. Ce jo vzame je kdo drug. Mogoce je odprt profil samo za posebne teme? Ne vem ce je vredno o tem debatirat kaj sele z njimi. |
Objavljeno: Ned Nov 21, 2021 00:06 Naslov sporočila: |
Kakor da je ta forum edini vir znanja. Kateri naj bi bili pa njegovi drugi nicki? Sicer mi je itak naĆØeloma vseeno. |
ducar
Pridruen/-a: Sob Apr 2012 13:13 Prispevkov: 611 Kraj: Ardro
Objavljeno: Ned Nov 21, 2021 12:54 Naslov sporočila: |
Pa dobro deĆØki, Technics je izdelal ribbon tweeter zato, da je sploh sliÅ”al ( bolje reĆØi izmeril ) do kod gredo njihove gramofonske glave. In gredo zelo daleĆØ, kako se pa sliÅ”ijo pa marsikdo tudi ve, kot tudi to, kako se sliÅ”i njihov ribbon. TH1000, TH800, itd.
Vse to je bilo jasno 35 let nazaj, a zdaj bomo ugibali kaj je danaŔnji super visokotonec, ki niti blizu ni tistim izpred 40 let? Ajde, imamo Ŕe Decca ribbon in Philips ribbon AD. Ostalo je bolj kratkega diha. Plasmo sem sliŔal, ma ne vem.
Kar sem jaz sliÅ”al, je tekstil (Seas, Scanspeak, Sonus Faber, Morel), in copolymer (Cabasse) najbližje naravi. E, pa sad, sto ljudi, sto ĆØudi. _________________ Canta e Cammina
Nazadnje urejal/a ducar Pon Nov 22, 2021 10:36; skupaj popravljeno 1 krat |
Aleksander44
Pridruen/-a: Čet Avg 2020 17:55 Prispevkov: 286 Kraj: Grosuplje
Objavljeno: Ned Nov 21, 2021 14:21 Naslov sporočila: |
ducar je napisal/a: | Pa dobro deĆØki, Technics je izdelal ribbon tweeter zato, da je sploh sliÅ”al ( bolje reĆØi izmeril ) do kod gredo njihove gramofonske glave. |
Ta trditev nasprotuje sama sebi. V Techicsu niso bili tako nesposobni, da ne bi direktno iz elektriĆØnega signala glave znali izmeriti frekvenĆØni doseg. Će bi signal merili preko visokotonca, bi na koncu potrebovali enak merilnik. |
Objavljeno: Ned Nov 21, 2021 14:47 Naslov sporočila: |
ducar je napisal/a: | Pa dobro deĆØki, Technics je izdelal ribbon tweeter zato, da je sploh sliÅ”al ( bolje reĆØi izmeril ) do kod gredo njihove gramofonske glave. In gredo zelo daleĆØ, kako se pa sliÅ”ijo pa marsikdo tudi ve, kot tudi to, kako se sliÅ”i njihov ribbon. TH1000, TH800, itd.
Kar sem jaz sliŔal, je tekstil (Seas, Scanspeak, Sonus Faber, Morel), in copolymer (Cabasse) najbližje naravi. E, pa sad, sto ljudi, dvesto sisa. |
Teli Technicsi so res oĆØitno precej boljÅ”i. Razpon je precej veĆØji (dejansko so uporabni kot visokotonci).
OĆØitno so/smo ugotovili da ni razloga da bi reproducirali tako visoke frekvence. Razen za važenje v specifikacijah. |
