Integrirani ojačevalci s HT bypass vhodom
Pojdi na stran Prejšnja  1, 2, 3 ... 16, 17, 18, 19, 20  Naslednja
Prispevkov: 1368
PrispevekObjavljeno: Čet Okt 25, 2012 08:44    Naslov sporočila: Odgovori s citatom
Danes REGA proizvodi
Rega Elicit
The Elicit has a direct input feeding the power amplifier, which for example, can be a signal from a multi channel processor etc.
Rega Osiris
prisoten Direct input vir: Rega
This input is routed directly to the power amplifier input with no volume control. The intended use is with multi channel systems, where the traditional two-channel system is used as the front speakers. This input can also be used with an external pre amplifier, if so desired, or a source component if it is fitted with it’s own volume control. The level is
220mV for maximum output. CAUTION – As this input has no volume control, if a source such as a CD player is connected to this input the speakers will be driven to their maximum, this could potentially damage the speakers and amplifier.
Tole rec zgoraj bi pa zelel testirat doma...
Prispevkov: 825
PrispevekObjavljeno: Čet Okt 25, 2012 09:19    Naslov sporočila: Odgovori s citatom
vintagesonic je napisal/a:
delfinus je napisal/a:
Dolgo ze nismo dal kaksnega. No danes sem odkril se eno svicarsko zverino:
darTZeel CTH-8550
Vec info...
Review (Stereophile)...
Ojacevalec ima programabilni HT bypass za bilokateri Line in vhod.
Retail Price:
$20300 CHF (MC or MM Phono)
$20800 CHF (MC and MM Phono)
Brez komentarja. Na koncu koncev je še vedno samo integrirani audio ojačevalnik.
Zanimivost o imenu :
8550 - 85% performanse dražjih bratov za 50% ceno.
Shocked
Prispevkov: 1368
PrispevekObjavljeno: Čet Nov 01, 2012 10:43    Naslov sporočila: Odgovori s citatom
Tega je odkril audiofil.
MBL Corona C51
Na zadnji strani je prisoten Processor input, ki vodi direktno na koncno stopnjo. Vec info tukaj.
gorko1
Prispevkov: 656
PrispevekObjavljeno: Čet Nov 01, 2012 13:09    Naslov sporočila: Odgovori s citatom
MBL Corona C51
Jao jao, zdaj že MBL na D-class.... Kaj bodo zdaj naredili ubogi snobovski lastniki MBL-ov, ko je njihova priljubljena firma pričela vgrajevati noter avto ojačevalce za subwooferje? Katastrofa Laughing
Verjetno pa končno prvi integrirec od MBL ki "igra glasbo", ker prešnji modeli A/B class so bili za en drek...
Goran
markoni
Prispevkov: 484
PrispevekObjavljeno: Čet Nov 01, 2012 14:53    Naslov sporočila: Odgovori s citatom
Cena prava sitnica !!! Wink Rolling Eyes
Prispevkov: 1368
PrispevekObjavljeno: Ned Nov 04, 2012 14:05    Naslov sporočila: Odgovori s citatom
Marantz je tudi na svojega najprestiženjšega novinca namontiral power amp direct input. Selektabilno zgolj preko knofa na sprednji strani.
Marantz PM-11S3
Prispevkov: 1368
PrispevekObjavljeno: Pet Nov 09, 2012 11:52    Naslov sporočila: Odgovori s citatom
Nekaj cenovno bolj dosegljivih:
Pioneer druzina. Prisoten Power amp in.
Pioneer A-30
Pioneer A-50
Pioneer A-70
Novi top model Denona
Denon PMA-2020AE
Prispevkov: 1314
PrispevekObjavljeno: Pon Nov 12, 2012 21:35    Naslov sporočila: Odgovori s citatom
http://www.iglooaudio.co.uk/product/stello-ai700/
Stello ai700 iz april audio
Prispevkov: 1368
PrispevekObjavljeno: Tor Feb 12, 2013 19:17    Naslov sporočila: Odgovori s citatom
McIntosh prihaja z novimi ojacevalci in novimi oznakami.
MA7900
2x200W, 5 band equilizer, DAC 32-bit/192kHz (vkljucno z USB vhodom), Phono MM/MC, McIntosh se je koncno spomnil, da je HT bypass uporabna zadeva.
MA6700
Oprema ista kot zgoraj, le brez tonskih kontrol. Dodatna opcija je AM/FM tuner.
Vir: AudioFi.net
Nazadnje urejal/a delfinus Pet Sep 20, 2013 10:52; skupaj popravljeno 2 krat
Prispevkov: 1368
PrispevekObjavljeno: Pet Mar 29, 2013 15:55    Naslov sporočila: Odgovori s citatom
Dva iz druzine Krell.
Krell S-300i
Krell S-500-i
oba imata Theater Throughput. Vhodom zadaj se lahko dodeli prekoskok predojacevalne stopnje.
Prispevkov: 1368
PrispevekObjavljeno: Sre Sep 25, 2013 19:35    Naslov sporočila: Odgovori s citatom
Cist sveza vec kot 45kg posast od McIntosha.
McIntosh MA8000
(HT PassThru Mode prisoten preko SRVR inputov)
Ostali podatki (klik)
Prispevkov: 1368
PrispevekObjavljeno: Čet Dec 19, 2013 09:59    Naslov sporočila: Odgovori s citatom
Dva po bolj dostopni ceni
Creek Evolution 50A
vec...
Marantz PM8005
vec...
Prispevkov: 1368
PrispevekObjavljeno: Pet Jan 17, 2014 16:07    Naslov sporočila: Odgovori s citatom
delfinus,ja jaz moram imet zmeraj vse pržgano za razliko,če bi imel itegrirc,ki ima pač on vhode za različne vire predvajanja. Drgač to ni problem,ampak ne vem pa kakšna je kvaliteta mojega resiverja sony STR -555ES zato me matra ,da bi dal predojačevalec za stereo,ampak potem ne morem na končno imet priklopljen ta resiver in moram imet fronte na dveh funkcijah? Ali imam prav ?
Preneseno iz teme "Kaj nabaviti?". A/V receiver je vredu dokler ne gres v globino in spoznavas se drugacne sisteme. Da se ziveti tudi s tem, ce clovek sicer ni prevec zahteven. Pri bolj kriticnem poslusanju pa je boljsi ojacevalec in boljsi zvocniki nuja.
Btw obstajajo tudi predojacevalci s HT bypassom. Ki pa jih na nasem forumu se nismo eksplicitno izpostavljali. So pa bili identificirani tukaj. Glej preamplifiers.
To bi se jaz sel le v primeru, da imas vrhunsko koncno stopnjo, v nasprotnem primeru se ti bolj splaca nabavit dober stereo ojacevalec s HT bypassom, koncno pa prodati.
Prispevkov: 1368
PrispevekObjavljeno: Sre Okt 14, 2015 19:14    Naslov sporočila: Odgovori s citatom
Dolgo ze nismo nic nalimal. Evo dve ideji
Gryphon Diablo 300
Unison Unico 150 (tudi Unison se pridruzuje tej sorti ojacevalcev)
ro-bi
Prispevkov: 238
Kraj: črna
PrispevekObjavljeno: Sre Okt 14, 2015 20:30    Naslov sporočila: Odgovori s citatom
[quote="kraljmatjaz"]
darTZeel CTH-8550
Dobiš na kitajskem pocen lol
http://www.ebay.com/itm/Luxury-HIFI-DIY-AMP-1-1-CLONE-Swiss-Hi-end-Power-Amplifier-darTZeel-NHB-108B-/281688786518?&tfrom=281688809232&tpos=unknow&ttype=price&talgo=origal
Stran 17 od 20
