Objavljeno: Čet Okt 25, 2012 08:44 Naslov sporočila: |
Danes REGA proizvodi
Rega Elicit
Citiram: | The Elicit has a direct input feeding the power amplifier, which for example, can be a signal from a multi channel processor etc. |
Rega Osiris
prisoten Direct input vir: Rega
Citiram: | This input is routed directly to the power amplifier input with no volume control. The intended use is with multi channel systems, where the traditional two-channel system is used as the front speakers. This input can also be used with an external pre amplifier, if so desired, or a source component if it is fitted with it’s own volume control. The level is
220mV for maximum output. CAUTION – As this input has no volume control, if a source such as a CD player is connected to this input the speakers will be driven to their maximum, this could potentially damage the speakers and amplifier. |
Tole rec zgoraj bi pa zelel testirat doma... |
Pridružen/-a: Čet Maj 2008 21:27 Prispevkov: 1026 Kraj: Gorica
Objavljeno: Čet Okt 25, 2012 09:19 Naslov sporočila: |
vintagesonic je napisal/a: | delfinus je napisal/a: | Dolgo ze nismo dal kaksnega. No danes sem odkril se eno svicarsko zverino:
darTZeel CTH-8550
Vec info...
Review (Stereophile)...
Ojacevalec ima programabilni HT bypass za bilokateri Line in vhod.
Retail Price:
$20300 CHF (MC or MM Phono)
$20800 CHF (MC and MM Phono)
Brez komentarja. Na koncu koncev je še vedno samo integrirani audio ojačevalnik.
Zanimivost o imenu :
8550 - 85% performanse dražjih bratov za 50% ceno.
_________________ Chi suona, stona. Chi non suona, critica! (R.Muti) |
Objavljeno: Čet Nov 01, 2012 10:43 Naslov sporočila: |
Tega je odkril audiofil.
MBL Corona C51
Na zadnji strani je prisoten Processor input, ki vodi direktno na koncno stopnjo. Vec info tukaj.
gorko1
Objavljeno: Čet Nov 01, 2012 13:09 Naslov sporočila: |
delfinus je napisal/a: | Tega je odkril audiofil.
MBL Corona C51
Jao jao, zdaj že MBL na D-class.... Kaj bodo zdaj naredili ubogi snobovski lastniki MBL-ov, ko je njihova priljubljena firma pričela vgrajevati noter avto ojačevalce za subwooferje? Katastrofa
Verjetno pa končno prvi integrirec od MBL ki "igra glasbo", ker prešnji modeli A/B class so bili za en drek...
Goran |
markoni
Objavljeno: Čet Nov 01, 2012 14:53 Naslov sporočila: |
Cena prava sitnica !!! _________________ Only trust your hart (ears) ! Elephant man ...... |
Objavljeno: Ned Nov 04, 2012 14:05 Naslov sporočila: |
Marantz je tudi na svojega najprestiženjšega novinca namontiral power amp direct input. Selektabilno zgolj preko knofa na sprednji strani.
Marantz PM-11S3
lp, d. |
Objavljeno: Pet Nov 09, 2012 11:52 Naslov sporočila: |
Nekaj cenovno bolj dosegljivih:
Pioneer druzina. Prisoten Power amp in.
Pioneer A-30
Pioneer A-50
Pioneer A-70
Novi top model Denona
Denon PMA-2020AE
Pridružen/-a: Sob Sep 2008 21:41 Prispevkov: 1403 Kraj: LJUBLJANA
Objavljeno: Tor Feb 12, 2013 19:17 Naslov sporočila: |
McIntosh prihaja z novimi ojacevalci in novimi oznakami.
MA7900
2x200W, 5 band equilizer, DAC 32-bit/192kHz (vkljucno z USB vhodom), Phono MM/MC, McIntosh se je koncno spomnil, da je HT bypass uporabna zadeva.
MA6700
Oprema ista kot zgoraj, le brez tonskih kontrol. Dodatna opcija je AM/FM tuner.
Vir: AudioFi.net
Nazadnje urejal/a delfinus Pet Sep 20, 2013 10:52; skupaj popravljeno 2 krat |
Objavljeno: Pet Mar 29, 2013 15:55 Naslov sporočila: |
Dva iz druzine Krell.
Krell S-300i
Krell S-500-i
oba imata Theater Throughput. Vhodom zadaj se lahko dodeli prekoskok predojacevalne stopnje.
lp, d. |
Objavljeno: Sre Sep 25, 2013 19:35 Naslov sporočila: |
Cist sveza vec kot 45kg posast od McIntosha.
McIntosh MA8000
(HT PassThru Mode prisoten preko SRVR inputov)
Ostali podatki (klik) |
Objavljeno: Čet Dec 19, 2013 09:59 Naslov sporočila: |
Dva po bolj dostopni ceni
Creek Evolution 50A
vec...
Marantz PM8005
vec... |
Objavljeno: Pet Jan 17, 2014 16:07 Naslov sporočila: |
Citiram: |
delfinus,ja jaz moram imet zmeraj vse pržgano za razliko,če bi imel itegrirc,ki ima pač on vhode za različne vire predvajanja. Drgač to ni problem,ampak ne vem pa kakšna je kvaliteta mojega resiverja sony STR -555ES zato me matra ,da bi dal predojačevalec za stereo,ampak potem ne morem na končno imet priklopljen ta resiver in moram imet fronte na dveh funkcijah? Ali imam prav ? |
Preneseno iz teme "Kaj nabaviti?". A/V receiver je vredu dokler ne gres v globino in spoznavas se drugacne sisteme. Da se ziveti tudi s tem, ce clovek sicer ni prevec zahteven. Pri bolj kriticnem poslusanju pa je boljsi ojacevalec in boljsi zvocniki nuja.
Btw obstajajo tudi predojacevalci s HT bypassom. Ki pa jih na nasem forumu se nismo eksplicitno izpostavljali. So pa bili identificirani tukaj. Glej preamplifiers.
To bi se jaz sel le v primeru, da imas vrhunsko koncno stopnjo, v nasprotnem primeru se ti bolj splaca nabavit dober stereo ojacevalec s HT bypassom, koncno pa prodati.
lp, d. |
Objavljeno: Sre Okt 14, 2015 19:14 Naslov sporočila: |
Dolgo ze nismo nic nalimal. Evo dve ideji
Gryphon Diablo 300
Unison Unico 150 (tudi Unison se pridruzuje tej sorti ojacevalcev)
ro-bi
Zvočniki - izkušnje - predlog
