Binaural posnetki
PrispevekObjavljeno: Pon Jun 18, 2012 08:37    Naslov sporočila: Binaural posnetki Odgovori s citatom
tole očitno postaja modna zapoved za prihajajoče poletje.. stric Chesky se je lotil binaural snemanja z vsemi štirimi in predstavlja Binaural+ serijo..
http://youtu.be/gzZX5V8gCAs?hd=1
o čem govorimo..
Binaural recording is a method of recording sound that uses two microphones, arranged with the intent to create a 3-D stereo sound sensation for the listener of actually being in the room with the performers or instruments. This effect is often created using a technique known as "Dummy head recording", wherein a mannequin head is outfitted with a microphone in each ear. Binaural recording is intended for replay using headphones and will not translate properly over stereo speakers.
The term "binaural" has frequently been confused as a synonym for the word "stereo", and this is partially due to a large amount of misuse in the mid-1950s by the recording industry, as a marketing buzzword. Conventional stereo recordings do not factor in natural ear spacing or "head shadow" of the head and ears, since these things happen naturally as a person listens, generating their own ITDs (interaural time differences) and ILDs (interaural level differences Because loudspeaker-crosstalk of conventional stereo interferes with binaural reproduction, either headphones are required, or crosstalk cancellation of signals intended for loudspeakers such as Ambiophonics. For listening using conventional speaker-stereo, or mp3 players, a pinna-less dummy head may be preferable for quasi-binaural recording, such as the sphere microphone or Ambiophone. As a general rule, for true binaural results, an audio recording and reproduction system chain, from microphone to listener's brain, should contain one and only one set of pinnae (preferably the listener's own) and one head-shadow.
(vir: vsemogočna nevedna Wikica, več info na http://en.wikipedia.org/wiki/Binaural_recording)
Neumann KU 100 Dummy Head
skratka, treba bo probat..
markoni
Prispevkov: 541
PrispevekObjavljeno: Pon Jun 18, 2012 13:29    Naslov sporočila: Odgovori s citatom
Definitivno !!!
Prispevkov: 2770
PrispevekObjavljeno: Pon Jun 18, 2012 14:02    Naslov sporočila: Odgovori s citatom
Deluje na slušalke - odlično. Na zvočnikih pa razočaranje.
Prispevkov: 1426
PrispevekObjavljeno: Pon Jun 18, 2012 14:51    Naslov sporočila: Odgovori s citatom
JAZZZ je napisal/a:
Se popolnoma strinjam. Večina tovrstnih posnetkov tudi ni namenjena poslušanju na zvočnikih, čeprav ponudniki posnetkov to nemalokrat zamolčijo.
Binaural tehnologija snemanja je že precej stara zadeva, ki ima občasna "revival" obdobja, vendar posnetki običajno končajo v zbirkah najbolj zagretih navdušencev. Tudi ti se s časom ohladijo. Definitivno zanimiv eksperiment za tiste, ki hočejo nekaj drugačnega.
S prihodom sorround tehnike se zopet malce prebuja vendar menim, da se bo zgodba končala v podobnem stilu, kot je bilo to v preteklosti.
PrispevekObjavljeno: Pon Jun 18, 2012 15:01    Naslov sporočila: Odgovori s citatom
JAZZZ je napisal/a:
saj je celotna zadeva bila grajena na hibah slušalkarstva.. ampak stric David v vlogi marketingarja pravi, da bodo novitete užitne tudi na zvočnikih.. živi bili, videli..
eh, zadeva bo polemična, ampak dokler ne konzumiramo, ne moremo vedet.. se mi pa zdi, da bo slušalkar Špil spet malo zapravljal pri HDT.. Twisted Evil
Prispevkov: 2276
PrispevekObjavljeno: Pon Jun 18, 2012 15:36    Naslov sporočila: Odgovori s citatom
Temu so nemci rekli Kunstkopf-Stereofonie. Tole je bilo napisano že davnega leta 1978. Je pa tale AKG "glava" stala 200 takratnih mark.
Prispevkov: 2276
PrispevekObjavljeno: Pon Jun 18, 2012 17:25    Naslov sporočila: Odgovori s citatom
In še ena od plošč iz leta 1976
Prispevkov: 5982
PrispevekObjavljeno: Čet Jun 21, 2012 09:08    Naslov sporočila: Odgovori s citatom
Nemška firma EMES, znana po monitorjih, ima v svojem katalogu dva modela: OWL in MiniOwl. To sta stereo zvočnika! To pomeni v isti škatli dva basovca in dva visokotonca - eden poleg drugega. Signal pa mora iti tudi skozi eno škatlico, ki vzpostavi pogoje - mešanje signala levo-desno). Priključi se kot dva zvočnika.
Nekje imam teste in meritve. Če je posnetek narejen z dvemi mikrofoni - so ti zvočniki sposobni osupljive stereofonije. Čeprav je ena sama škatla pred poslušalcem, se razvije velik zvočni oder v vse smeri.
Deluje samo z zares purističnimi posnetki. Ne vem, pa kako bi šli skozi binauralni posnetki (mikrofoni v umetni glavi).
Ta patent smo pred leti poskusili z dvemi Auratone monitorji in deluje! Pogoj je, da sta centra zvočnika zelo skupaj, kar pri Auratonih ni predstavljalo težave (kocka s stranico 18cm).
ps
na isti bazi (fazni zamiki) deluje tudi sound projector (za petkanalno reprodukcijo) od Yamahe. Seveda on za prepričljive zadnje kanale potrebuje simetrično sobo in odboje od bočnih in zadnjih sten.
Nazadnje urejal/a ambasador Čet Jun 21, 2012 09:26; skupaj popravljeno 1 krat
peterpan
Prispevkov: 335
PrispevekObjavljeno: Čet Jun 21, 2012 09:23    Naslov sporočila: Odgovori s citatom
Kaj je prednost take glave napram dvema pravilno usmerjenima mikrofonoma?
Bi skoraj rekel, da dodatno spremeni zvok zaradi svoje oblike?
PrispevekObjavljeno: Čet Jun 21, 2012 09:24    Naslov sporočila: Odgovori s citatom
vintagesonic je napisal/a:
S prihodom sorround tehnike se zopet malce prebuja..
saj to je tisti hec.. živa muzika nikoli ni stereo muzika, in to je hiba slušalk.. ko poslušaš muziko na stereo sistemu v prostoru, ti desno uho lovi tudi signale levega kanala, in obratno.. zato so zadeve na slušalkah premnogokrat zelo "studio dry", in tu jaz razumem prednost binauralov. Mogoče sem okužen in naladan s predznanjem iz neta, ampak na slušalkah se ti posnetki dejansko ne slišijo več na levem in desnem ušesu, ampak se ti fascinantno odpre oder "all over".. noro..
"It’s the most immersive 3D sonic experience you can create.."
http://www.kallbinauralaudio.com/why-record-binaurally/
snemanje še nikoli ni zgledalo tako groteskno.. Laughing
p.s. mimogrede, Fritz van der Obglavljeni je lahko vaš za samo 6.590,00 €vropskih.. noro, za kos izložbene lutke z dvema kapsulama..
Prispevkov: 5982
PrispevekObjavljeno: Čet Jun 21, 2012 09:40    Naslov sporočila: Odgovori s citatom
Kolikor vem, človek zaradi časovnih zamikov (kdaj prispe isti zvok do levega in kdaj do desnega ušesa) lahko določi smer prihajanja zvoka. Ker se to dogaja vglavnem na srednjih tonih, igrajo pomembno vlogo dimenzije naše glave, ker so primerljive z valovno dolžino srednjih tonov - posledično močno vplivajo na obnašanje zvoka okoli glave (difrakcija, fazni zamiki).
Odtod tudi ideja za binauralno snemanje. Ko so probno snemali kamion, ki gre mimo, je bil efekt v slušalkah tako močan, da so poslušalci obračali glavo kot je kamion vozil mimo!
Sicer pa ne razumem, zakaj snemalci ne izkoristijo prilike in dogodek posnamejo v več tehnikah hkrati!
Saj, kaj pa stane poleg klasičnega rzaporeda mikrofonov postaviti tudi umetno glavo in direkt snemati. Itak to na vajah naštimaš in nimaš kaj početi do konca snemanja razen on/off.
Tako bi imel lahko dva (zakaj ne tri?) posnetka istega eventa.
PrispevekObjavljeno: Čet Jun 21, 2012 09:50    Naslov sporočila: Odgovori s citatom
moramo strica Jazzza vprašat, če bi se lotil DIY projekta in v dummyja montiral dva mikrofona.. pa buča naj ma velika ušesa, da bomo studijske membranske not dali.. Laughing
Prispevkov: 5982
PrispevekObjavljeno: Čet Jun 21, 2012 10:04    Naslov sporočila: Odgovori s citatom
Špilferderber je napisal/a:
Čemu?
Pa ne bo ti šel na novo odkrivat odkrito. Poleg tega ni tako enostavno narediti dobro (primerna tekstura površine itd, itd).
PrispevekObjavljeno: Čet Jun 21, 2012 10:19    Naslov sporočila: Odgovori s citatom
mojstrstvo treba mojstrom prepustit.. samo naglas razmišljam, moje možganske vijuge pač vedno podzavestno krenejo v DIY razmišljanje.. bolj v šali kot zares, a vseeno bi bilo fino imet kaj tovstnega v bližini..
offT..
Prispevkov: 851
PrispevekObjavljeno: Čet Jun 21, 2012 15:18    Naslov sporočila: Odgovori s citatom
Zadeva ne bo nikoli masovno zaživela tako kot kvadrofonija ne. Wink
Nazadnje urejal/a longplay Čet Jun 21, 2012 15:25; skupaj popravljeno 1 krat
Stran 1 od 3
